Free Willie
So after the successful test I discovered that it is too easy to rotate, not good when working on a bike but it does need to rotate a 1/4 turn when using as an elevator so it needed an anti-rotational device
that would be easy to disconnect when needed.
This is what I came up with. 1 pipe inside another. The bigger pipe is welded to the wall of the enclosure and with a 5' section of the smaller pipe inside and pinned to the hat. Keeps it straight going up and down and unpins when it needs to rotate.
