IMCA38
BACKGROUND-
I got my original air compressor back when I first got my own garage, around 1992. I went to Sears one day to look at a modest portable unit. They had a 5HP/ 30 gallon unit on the floor that had been closed out. The clerk told me that if I was interested in that one, he'd make me a deal just to get rid of it.
If memory serves me right, he knocked 10% off of the clearance price, and as it had been used as a "donor" unit for some small parts, he started pulling items off of the hooks to make sure it was complete. I recall that he pulled a regulator, a couple of pressure gauges, some fittings, a bottle of oil, etc.
I put everything together, ran a 220 line to the garage and I was in business!
A few years later, we moved to our first acreage, and the compressor was moved into my new detached shop. I added a hose reel on the wall and later on, an old tire machine. These were connected using short whip hoses and a brass tee connector.
In 2000, we moved to our current place and I got a sheep barn to repurpose as a shop.
As I planned the remodel of the barn, I built out a storage room in one corner and put the air compressor in that room so I could shut the door and have some quiet.
At that time, I had designs of sometime moving up to a larger unit, so I built the area out with that in mind. We ran an electrical sub panel into the room and ran a 220 outlet from that for the existing compressor.
Having the subpanel in place was one of the steps to plan for an eventual larger compressor.
I put a regulator/filter on the wall and ran out 1/2" PVC lines with several outlets.
This setup worked well and I never seriously looked at a new compressor as the 10cfm/90psi air delivery of the Craftsman was close to what a cheap upright unit will do.
I ended up getting a large bead blast cabinet a couple of years ago, and that was likely the beginning of the end for the old Craftsman.
Last winter, I went to start it one night and it wouldn't move. I opened it up to discover one of the rods galled onto the crank journal. Probably a combination of overheating and maybe low oil.
One of my peeves on the Craftsman was how hard it was to accurately check the oil level with the shallow "tee" that came out of the oil pan.
I briefly considered trying to fix it, but found parts non-existent.
Here are a couple pics of the old Craftsman and my space in the storage room.
