MatBirch
I finally got a start on my blasting cabinet. I modified a set of plans that I found online for a wood cabinet. I am using 1/8" aluminum. I broke out the upper half, and welded the hopper up out of individual plates. I'll get around to sides and a door.
I will add a vent and vac port, get the gloves hooked up, and add some lights. I have a couple of the caged, glass dome sealed explosion proof light fixtures. I'm gonna run EMT with sealed compression fittings for the electrical.
The window is a tempered RV window that was left over from a project at work. I have to drill and attach it through the face frame instead of using the clamp ring, because it's designed for a 2" thick wall, not 1/8" plate. I will use the holes for the clamp ring to attach a piece of plexi to be a sacrificial layer.
The upper half of the cabinet is 48" wide, 30" deep, and the back is 30" high. The window is 24"x24".
