My Horizontal/Vertical Porta bandsaw Stand
vettelvr75
Norman, OK
After reading KMinAF's portable bandsaw stand thread,(http://garagejournal.com/forum/showthread.php?t=240721) I decided that I needed to build my own. I have been wanting a bandsaw for a long time now but don't have the space for one. I am also transferring to University of Oklahoma in a few months so I have to start thinking about space in the bed of my truck. So a full size bandsaw was not the answer, however, I wanted to build a portable bandsaw stand that would allow a vertical position and a horizontal "Chop saw" style position. After a couple hours of scribbling plans on a notepad, I had enough of an idea to start making it. Here is the building process. I am learning a lot from fabricating everything I have been doing. I have only been welding for about a month and I love it. If anyone sees something they would have done differently or has any advice, please speak up don't be shy! It would be greatly appreciated. I am eager to learn more. I am not quite done yet but I will be updating as I am building. Heres what I got so far:
I started on building how I was going to connect to the bandsaw itself. For the sake of budget, I went with the harbor freight bandsaw. Out the door with a 25% off coupon I spent $67.82. Fortunately I have a buddy who works at a huge metalworking shop so I can get basically anything I need for free from their remnants. So the only cost to me was the bandsaw itself and my time.
I made these two brackets to bolt onto the bandsaw. I used some 1/8" bar stock with holes drilled and countersunk for the 10-24 Phillips head screws. I then plug welded the screws into the metal and ground it smooth so I could cut the small pieces of 1 1/2" tubing to it. They are mitered at a 45 degree angle because I needed to achieve a 90 degree angle with the blade.
Here is a close up of one of the welds on the first pieces I made.
After the two brackets were installed, I cut a piece of tubing about an inch longer than I figured I needs, and welded it in to one of the brackets. I couldn't figure out a way to calculate how long each piece needed to be in order for them to be at a 90 degree angle, so this is the way that I did it.
Once I got that piece welded in, I was able to take a square and measure the distance between it and the other bracket, so I could cut a 45 at the proper length. Then another piece was cut and added into the other side.
Then I made some approximate measurements as to what I wanted the sixe of the stand to be, and cut pieces to make it.
The four pieces were then tacked together using miter clamps to assure proper angles, and then the whole frame was clamped down to my table before I welded it fully to try to reduce warpage. I alternated sides while welding and allowed the frame to fully cool before un clamping it and flipping it over.
After it was fully welded, I spent some time with the angle grinder and flap disk smoothing out the welds.
Then this piece was made. This is what the bandsaw will sit on. It will have a hinge connecting it to the bandsaw allowing for horizontal cutting. If it is hard to visualize for you, I should have pics up soon of the bandsaw permanently connected to the stand. I had to do short weld beads because I was using a fairly thin tubing, and I was having a problem with burning through the metal. Everything was ground smooth anyway.
And lastly, here is the stand section tacked to the frame. This is all that I currently have but will have some more pics up soon of the rest of the project. Thank y'all for reading I hope this can help someone who has been wanting to do this!
cg81
Very cool. I will add that to my list of things to build.
bad_idea
Pasquotank, NC
I am curious to see where this is going. Good skills. To find dimensions, it is easier to lay it out on the table to scale.
V
vettelvr75
Norman, OK
Following along.....I am curious, as to how this is gonna turn out.
Keep the pics coming. :D
I am going to be able to work on it some more today so there will be an update with pics tonight! Thanks for following along!
Thanks! And thanks for the tip.
Can't wait to see the finished pic. Good job.
Thank you! stay tuned for the next update!
I am working right now on brainstorming a custom built vice that will be like a drill press vice but have adjustment to cut at 22.5 and 45 degree angles. I looked online for something like this and couldn't find anything. Basically I will be creating a replica of what you see on a full size horizontal bandsaw, but will be smaller to fit on my stand.
-Brent-
Utah
If you keep it simple, I think this is an idea you may be able to sell.
Can't wait to see more.
V
vettelvr75
Norman, OK
Here is a photo I snapped this morning of my current position, not the best pic but you can at least see how I joined my frame and bandsaw together. If you look closely, you can see the hinge between the two pieces of tubing. I ground everything smooth for a cleaner look, so the hinge is kind of hidden.
More updates to come this evening.
Thanks for following!
Rhyno
Salt on the left, Mormons on the right, Yup, "This
Before you get too much further.....the hinge that you have pictured, looks to be a gate or door hinge.
I'd imagine, that particular hinge style is too sloppy, and will make the saw not hold to "perpendicular."
Two of these.......
will be a lot tighter.
I have bought and used many.....got them at my Local Welding Supply Store.
V
vettelvr75
Norman, OK
Two of these.......
I thought that it may be sloppy, however once the weight of the saw goes down on the hinge there is hardly any slop and it is perpendicular as well. But thanks for the tip I will definitely use those next time, just this was supposed to be as low budget as I could make it and I already had the hinge layin around.
V
vettelvr75
Norman, OK
Well I didn't make too much progress yesterday, I am still kind of figuring out how the miter vise is going to work as I am building it... So I cut a 5.25" x 5" piece of 1/8" plate to use for the "table" of the vise.
I then figured out where I needed to start with drilling my holes, I will be using 1/4x20 hardware, so 1/4" holes needed to be drilled. One side will have a slot for a piece to slide on and out, and one side will have one hole towards the side where the "Clamp" will pivot.
This is the side with the slot, if you can see the hole I am drilling and then just to the left is a punch mark for another hole, then I will cut out the metal in between leaving a slot.
here is the pivoting side for the "miter" I will be welding a bolt to the underside of the plate, so that the nut on top can be easily tightened/loosened as needed to pivot. There will be a modified c clamp welded to this piece, and that will be what will be used to clamp material to the surface while cutting.
This is an example of the pivot. It will be able to swing 90 degrees, and I will be making marks for the important degree readings.
I hope some of this is making sense for you guys, I know its hard to visualize it when its halfway done. hopefully I can get some more work done on it soon and show you the finished product so there will be some clarification. As always, I appreciate your comments and advice! Its not too late to completely start over on this vice!
