My IR SS5 air compressor
paul2112
Waxahachie,TX
Years ago when I was doing soda blasting, i purchased two of these unit,,,I think for like 150 ea.. Had them mounting on big 185CFM diesel compressor..Worked great
StangStang
Got my aftercooler done. Just need to do some testing. See attached
hemidad
Magnolia, TX
Nice work! How did you attach the water separator? I am installing a Master Pneumatic BFC100-6X. It looks as if you drilled and tapped the four top holes and attached with nuts/washers. If so, what size studs did you use? I was planning on using a no. 29 drill bit and tapping for a 10-24 stud. Thanks in advance fo any help.
