My ‘new’ bittersweet purchase
Duke74
Pierceland
So I found a Starrett Athol vise for sale about a 10 minute drive from me. The lady sent me pictures and told me to make her an offer. I offered $25 and she readily accepted. My wife was going into town so she dropped the sellers house and picked up the vise for me. She gets it home and I eagerly can’t wait to see it. IT’S CRACKED! I didnt see it in the pictures before I bought it. So now I have to find someone who can weld it. The value of the vise is gone, with the crack or with it welded. Anyways....happy to have the vise but bummed about the crack....no pun intended.
matt_i
That's kind of impressive. Either a casting defect or someone really put a sledge on it with the moving jaw wide open. That "ledge" there is beefier on a Starrett vise than any other brand I've used (the analogous part on a Reed is wimpy and thin BTW). I would repair that cosmetically by vee-ing out the crack slightly and use flux coated bronze brazing rod (plus oxyacetylene) to repair it and metal-finish it with a file. Several generations of use would then be possible if one doesn't go crazy with it.
seber
Deep East Tx.
Brazing is the right way to fix it but I would add a tapped counterbored hole and install a machine screw. It will be stronger than the original casting.
Maui
Upstate NY
I found one of those back in 2015.
Very nice vise, and your vise is worth repairing in my opinion.
D
Duke74
Pierceland
Thanks for all the input. I will fix it up. Trying to match the existing original paint, after the fix, will be an obstacle unless I take ALL the paint off and repaint the whole thing a different colour. I hate messing with the original though.
Packard V8
Spokane, WA
Agree, someone wailed on it with a sledge early on and then it was taken out of service. Definitely worth a repair and can be a user forever after.
jack vines
dwasifar
You should absolutely fix it. It's not often you come across one of these anti-gravity vises. :D
830singleshot
If I had the opportunity to buy that for$25 KNOWING it was cracked, I would have been on that deal like a duck on a June bug.
That has to be a casting defect. Even the handle looks dead nuts straight. Spend the money on the right welder and enjoy that bad boy for the rest of your life.
BlueBomber
Outside Boston, MA
Well, you no longer have an "original" due to the crack. You might consider just using it as is until it actually breaks. If/when it does, you'll only get it welded, which is what you're already planning to do.
matt_i
I think the Starrett vise is NLA for quite awhile, ~20 years at minimum. I don't think you are going to get much out of warranty.
As Seber mentioned above, a socket head screw can definitely help out in "fitting the casting back together perfectly" but its worth some study, vises often have hollow spots where you are expecting solid material. Definitely want 1 diameter of thread engaged, a 3/8-16 would work well if you have the room.
I would think it will work just great as-is-no-further-action-is-taken with the exception of when you open the moving jaw very widely.
D
Duke74
Pierceland
Yeah, I also don’t think it will affect function really. I am a vise collector so maybe it’s worth it to just leave it alone, and keep it with as much original paint intact. Maybe the crack won’t be so noticeable on a shelf.
didit
S.W. Ontario
I have repaired similar damage by V-ing the crack, pre- heating with oxy/acetylene and stick welding with a nickle rod. The one on my bench has held up to continuous use 40 years after the repair but I wasn't looking for a collector/invisible repair.
