My Pawn Shop Hauls thread
JASTECH
Gering, NE
The Pawn Shop Hauls thread
As much pawn shop hauling I do and the rest of you too, it's about time eh? This thread seperation will better assist in others locating what they want to read.
Moderator, you can relocate all my PS Hauls here.
Thanks, JASTECH & Son
J
JASTECH
Gering, NE
Pawn Shop Haul #13
My son and I went to browse our special Pawn Shop and to pick up my N2M Blue Point Tool Cart w/2 Options, Pry bar/Screwdriver Lockable cover on the left side. The 2nd is the collapsable shelf on the right side. The top and right side shelf have heavy duty treaded rubber glued to the tops. Only 1 key for it, want to go Barrel Key locks and keys.
Now for the 2 item that followed me home.
#1) Black & Decker Master Bit set, this case of bits was 15+ dollars and so I paid $3.00. I will paint all the markings in the plastic w/bright yellow and replace bits as the brake with Quality.
#2) OEM Disc Caliper Tools $20.00
This kit seems lightly used, I figure a step above my 14" End-Groove ChannellLock Pliers.
#3) Air Hose 300psi Snap-On
I needed hose for the 7.5gal. air tank I bought their made by "Huskee" made by ICS Industries. The tank looks good steel and heavy but the pressure guage looked like a rock hit the face. The pipes need replace on it so tried at Menards then gave up and went home flustered. Pic if needed.
J
JASTECH
Gering, NE
Can a Moderator please take the MY of thread title, this is suppose to be for all pawn shop hauls. So please correct it so others can/will post what their pawn shops have to offer.
Thanks, JASTECH
J
JASTECH
Gering, NE
Jeff, Any comments? You are all welcome to comment, I accidently posted "MY" in title. Just wanted a Pawn Shop thread to compare ect.
Ryan, Please correct my mistake!
redwrench60
East Tennessee
I've had my local pawn shop manager in a headlock on a Snap-On ball joint press set he can't get rid of for a while, as soon as he gets his heart right on the dollar bills I'll post my "kill" here. :thumbup:
FunkyfullWidth
Three Rivers, ma
I got two snap on trim panel tools one rounded, one V for 6 bucks a peice. A blue point trim tool with the spring lever for 12, and a blue point flaring kit for 50 bucks... And a 17mm 3/8 snap on impact socket for 3 dollars. That was a good day.
vfr-rider
South Carolina, USA Earth
I scored a SO 1/4" air ratchet and an IR 3/8" air ratchet for $25ea the other week. Also a Proto 1/2" torque wrench with box for $50 from another shop the same day.
J
JASTECH
Gering, NE
Pawn Shop Haul #13
The ratchet like tool I don't know about, but the lot of tools was $2.00 and I figure them C'man skiggles are worth that? I bought the 2 Pro Lift jack stands for $15.00 out the door so I don't feel good abou that.
The box of steel from John Deer with carbide bits, 2 Peterson V-grips, Octopus lamp stand in stainless steel ect. walked out at $18.00 or so.
Rigid belt sander Heavy Duty I bought at Home Cheapo for $35.00 Clearanced not on file!
zuk123
Houston TX via Chicago, Phoenix, LA, and San Diego
Re: Pawn Shop Hauls thread
I've got a couple to post up. You definitely inspired me. I used to go in, look at all the brand new (stolen, or "I've just cash advanced my Sears card") stuff, selling for RETAIL or higher, and walk out.
Now, I'm looking for the rusty gold!
I got this Kennedy roller and top for $75. The top is rusty as anything, but solid. The bottom just needs scrubbing with degreaser.
It came with the tools in the pix, and some misc allens, etc not pictured.
The adjustables and the wizard ratchet were in a drawer I didn't open and there was a stuck one too...
Best of all, the drawer that was stuck shut turned out to have the dial indicators and mag bases!
There was a huge 24" Ridge tool pipe wrench in the bottom too.
I've already started working on the top. Rust removal, primer, and eventually brown hammertone paint. Never did like the Kennedy wrinkle, but always wanted one!
zuk
BOONEY7750
Picked up a 12" Proto adjsutable wrench for $10, a SK "battery" Plier for $3 and American old Vise grips for $5 at a random stop today.
zuk123
Since we seem to get lots of pix of the 'rusty gold' but not so many of the 'gold,' I'll post a few pix of stuff in its "after" state. That will help motivate me to not just buy, but clean and use/sell.
Starting with the kennedy top box, as a work in progress (not quite gold yet.)
Then a pawnshop c clamp, before and after.
Not super dramatic I know, but my wrench pix don't look much different even though they are dramatically improved. Pretty much every hammer I get, or yard tool, gets cleaned up and painted right away. (or oiled, depending on use and function.) No good pix though. (I'm using the little Plomb ball pein from the kennedy box to straighten the box.)
zuk
With 2 little girls, I need projects I can work on 20mins at a time. :p
zuk123
Here is some of a haul from a week ago. No time to post it as I was traveling for business. I was in a small, family pawnshop, a little further outside of town than I usually go. I spent 2 hours there and didn't get thru everything. I didn't even look at sockets.
Haul:
craftsman usa #3 phillips
craftsman usa #1 phillips
USA 1/4" driver
Usa (not excelite) precision flat head
USA channellok mini
USA stanley framing square
USA deep 4" c clamp (shown above)
20 oz Dead On framing hammer compare at $78
and
13 pounds of USA wrenches!!
all for $35.
zuk
starting with:
Bonney cam wrench (had to look this up, never saw one)
agricultural machine wrench, common (looked this up too)
powerkraft 6" 1/4 drive ratchet, already cleaned up and used
williams 1/2 extension, 12"
barcalo and williams (superwrench filled a hole in my set)
p & c
craftsman
indestro
To be continued---
zuk123
Gahh, I rotated them, but I guess it didn't stick.
Also missed the pic of the hammer.
continued:
more indestro? select steel
?? usa
champion,companion, giller, west-something
s-k tools
bonney, new and old
TruFit
westline
pennens
zuk123
Yesterday I stopped in at a store that is part of a local chain. Typical bunch of ladders and generators out front, overpriced truck brands under glass...
But they had wrenches and sockets in bins in the corner.
So, what the heck, I looked.
$15 take for the day,
6 wrenches, including a craftsman gear wrench,and a like new wizard
3 craftsman =v= sockets
3 craftsman -v- sockets
5 s-k sockets
2 possible Duro-Chrome sockets (did they use the stylized DC (circle x) mark on sockets?
nice craftsman tubing cutter, with sharp cutting wheels.
I'll probably go back and look for more s-k and =v= sockets.
zuk
nine4gmc
Dallas
I saw a local pawn shop ad in CL for a like new milwaukee portaband $100 so I call to see if its still there. dude says, "we had two, sold one" so I ask if its in good condition. he replies yes, warranty, blah blah blah. I drive over to check it out, looks way more used and marked $40 more than CL ad. I dig around and find a Indestro Super 3201 in the bin. I inquire about the saw, owner says we sold the one in the ad. I reply, well it was the clean one and you were asking $100, this one is clearly not as good of condition, will you take $80? he replies, "I'll take $90 tax included", I said throw in the ratchet and its a deal. His monkey rings me up for the $80 he heard me offer so I walked out with a Milwaukee band saw and the ratchet for $80. Deal?
J
JASTECH
Gering, NE
Zuk, nice deals, you shop like me. Now I have my left eye on a .22 WM rifle with clip and scope. Bull barrel or extra thick that I could see. I want to try $200 out the door. What do you gunny geeks think?
Jeff, you didn't comment on my OTC disc break pad kit, bad deal? Anybody know?
I just looked for the Rigid 2720 I paid $35 for and see it from $179 to $244 so I fill better for dropping the $35.
b225
Any more details? Model# or brand on the rifle or scope? What do they have it priced at?
J
JASTECH
Gering, NE
Here is Pawn Shop Haul #15
The rat strap was 9.95 so they gave me all of it for $10.00
The 2 Bull Jacks are HD clearance.
The 4 Grip rolls are 16" x 7' and $5.00 each.
J
JASTECH
Gering, NE
The Green handled screwdriver has metal all the way through to the hammer top. This is the 4th one, no name found. Ideas?
zuk123
TwoInch, thanks, I just searched ebay for the $78. Seemed high to me, but lots of the specialty framing hammers do. At $25, I don't get to gloat quite so much, but still a good deal.
Used it yesterday. Takes some getting used to the square head. I had a hard time hitting the points to set my joist hangers. I haven't tried setting the nail with the magnet part. When my bathroom framing project starts, I'll give it a try.
Who knew that there would be so much innovation in hammers and pry bars?
zuk
J
JASTECH
Gering, NE
No, the scope is called an M1 scope by AccuriteScope or something. Kinda leary, now looking at Mueller 4-16×50AO Tactical. But money talks and mine uses hand signs! Looking to spend $300 from tool sells for the scope. I like hitting my antelope at 800-1000 yrds and real good shot at 1500 yrds+. Now you know me a little more eh?
coolformula
Everytime I go to the local pawn shops...you might some beat up craftsman stuff thats not that old, that you could go buy new for cheaper!! They think if it says craftsman its worth gold! Everything else is stuff worse than HF...just no name chinese ****.
J
JASTECH
Gering, NE
Pawn Shop Haul #16
The crow foot line style is SK along with the 2 sockets lower right. The sockets on left bottom are all C'man laser etched. Then towards the right are Herbrand, Gribber? and 2 I will get better pics of tomarrow as my son and I just got back from the auction.
The awl is Proto, swival and bit socket with it are Stanley USA, the torq socket on lower left is Snappy. Out the door $2.63
J
JASTECH
Gering, NE
The 1" socket I am at a loss to Mfg., you guys have any ideas?
The slip-joint pliers are rusted but thought I could read Jamestown? on them so figured they are USA.
J
JASTECH
Gering, NE
Jeff, you maybe correct. This storm is slowing your plate, but think I may have located 2 more. Check out the Auction #2 I posted. I need to find new homes for some stuff, running out of bedroom space, lol
redwrench60
East Tennessee
We finally got together on the price, it was worth the wait :D It's never been used.
TheGrease
I went to the pawn shop a month ago looking around see what they had and they had a ir 1 inch impact gun for 300 and a mac muilti meter for 175. So I asked how much for both he said 300 bucks out the door. Ill post pics of it Monday when I get to work
J
JASTECH
Gering, NE
Been awhile so went to pawn shop to get my Stoeger X50 camo air rifle, MEK microscope and then these tools wanted to go home with me. How did I do?
J
JASTECH
Gering, NE
The Weller Soldering station, Wright socket set, Thor 1/2" impact with extras was $100.00 out the door. I may not be able to operate pellet rifle, if not then I will sell it.
