I have always wanted resinous coating on my garage floor and after spending hours researching forums and data sheets decided to go with Nohr-S system.
I have applied water based epoxy in my basement a few years ago and I was confident that I could do this.
I am close to being OCD-type when it comes to quality of my work, and I tend to re-do things until they are perfect.
In my basement I have a full flake system with many polyurethane coats sanded in-between for flat finish with no texture. My wife does not like the look of flakes, so for garage we decided to go with solid gray. Light gray to be exact, since it tends to cover scratches better and I tend to to quite a bit of work on my car in the garage (think dropping ****** - level work).
This project is still in progress and I will be updating this thread with results.
My garage is 297 sq. ft. I've decided to go with 301-550 sq ft kit to be safe.
My garage had 20-year old rough broom finish slab with some light pitting from salt and freeze/thaw cycles by the door.
Unfortunately I don't have a picture of old floor before prep, but it was very rough, however I would consider it to be in good overall shape.
In my basement I have used acid etch method for prep. While I have not had any issues with my floor in the basement, my garage could see heavier use, so I've decided to grind the floor.
After researching the diamabrush vs edco grider, I've decided on renting the grinder from HD. I don't own a truck and the grinder is 150lbs. Luckily for me, my local HD is just a mile away from my house. I've rented the grinder for 24 hours and just rolled in to my house and back. Grinding was going slow initially, until I've added 45lbs bumper plate on top of the grinder. That increased the productivity and I've finished grinding in 4 hours total. I've used the dry method with a large shop vac and a duststopper bucket for dust collection. Don't attempt to do this with a smaller shopvac. The fine silica particles will clog the filter very quickly. I've used HEPA filter with regular dust bags in vacuum in addition to the dust bucket. I ended up using two bags in the vac. You should probably be using proper self-cleaning dust collector, but I don't have one.
When your vac suction drops, check the hose connections. Dust tends to accumulate in the ends of hoses and blocks the air flow. Clear the obstructions and you could continue without changing the bag/filter.
With my setup I did not have any dust in the air. I had some heavier leftover dust on the floor, but nothing like grinding without the vac. I've finished off the corners with 4-inch grinder with a cup on it and a dust shroud. Again, no dust in the air. Even though there was no dust in the air, I still used proper PPE to be safe. Judging by the fact that there was no dust on any other surfaces after grinding I can conclude that my dust collection method worked well.
After grinding the floor and returning Edco grinder to HD, I've patched the holes and pitting in the floor with PC Products 72561 PC-Concrete Two-Part Epoxy Adhesive Paste and let it set overnight, followed by leveling it with my handheld grinder. This epoxy is super hard - it is much more difficult to grind than concrete.
Below is the pic of the prep work.
