Indy_500
I would not want to attempt your staircase.
that's cuz you'd break em
Thanks for the correction. We agree wood boxes retard rusting much better than do steel boxes. One thing most forget is Gerstner boxes have steel drawer bottoms.
A bit OT, but wish I could find a competent iron head porting shop in the NW. The two shops who did my heads both guys died off. Too much cast iron dust in the lungs, I guess. Take precautions!
jack vines
Actually that was my grandmothers bathroom chair. I took care of her in the last 6 months of her life. Hard for me to throw an metal out, I've been planning on making a workbench stool out of it Minus the toilet seat. I'm afraid of sitting on those things. I'm afraid I'll forget I still have my pants onLooking forward to seeing how it comes out.
And please give your grandmother back her bathroom chair!
Does any of the construction process require a router?
Very nice project! I hope that support/drawer divider works out for you though. Unless that's exterior plywood I've found glued and screwed endgrain joints without a dado swell with moisture and don't last. Maybe doubled up and vertical will work for you.
There will be furing strips along the bottom to box keep anything from catching on the bolts. I planned on putting in the strips when I thought of a roller slide that may break and to drawer locking up. Thanks for the tipLooks good and well planned so far.
You have protruding bolt heads from the caster attachments on the bottom piece. Nothing wrong with that, a little bit of extra strength over the alternative of countersinking them. However, be sure when building and fitting the bottom drawers to allow for them clearing the bolt heads, when loaded.
KEH
I reworked the cast Iron casters that are on it. I just wasn't going to shell out 600 dollars for casters on something that will only be moved maybe once a year and then only 10-15 feet.Good show! Keep us updated!
I am so glad I don't have to put up with inferior Casters...
http://www.nwcaster.com/
Right down the street from me.
Are you planning to band the plywood edges with something like say hardwood?
tks
I must have missed the fact that you were in a wheelchair before. Who is helping you manipulate this thing? That wood gets real heavy
Thanks a bunch, With me I have no time line to meet and I love a challange. I cut the back of the box today (60 dollar sheet of Oak and missed the measurement by the width of the blade. Because it's on the back I'll work it out but it really pissed me off.lolNice project, and I commend you sir, for your spirit and determination. See my signature.
Maybe you should have measure 16 times instead of 14
Makita I bought from my son. He had 3 of them and sold me one for 30 dollars with a box of Columbia bits. He wanted to give it to me but I wasn't having it so I paid for him and his wife to go out and eat. I can't imagine how they got out of Outback for 30 dollars. Cost me 50 at least for the wife and I. I've got to practice with that a bit before I go screwing up nice woodhow about glue and caulk?
Or wood putty.
It will look crappy but at least it's on the back.
What router did you get?
My son says he can fill that crack and I won't be able to tell. Like you he said "Hey it's on the back where you will have screw holes anyway". I want the back to be able to come on and off as I intend to build a locking systen for it and will need access. His other suggestion was to leave the crack and quit being so **** about it.how about glue and caulk?
Or wood putty.
Here is the problem I created today. Was wondering if I could shave down a peice of wood and glue it in the crack. The crack is about .045 all the way down. Any suggestions other than buying another sheet of this gold encusted plywood?
