OccupantRJ
I measured that thing I bet at least 10 times, made sure the lines and the board were square. Made the cut on the line. I guess i sould have cut on the outside of the line. I've been cutting just a hair large and sanding down to fit. I screwed to pooch this round.
Center it so there is half the crack width on each end, attach, then caulk with a butyl caulk, which remains very flexible. That way you end up with HALF the crack width, which is easier to hide. Wood filler will just crack later as the box flexes under weight. Found a link for you on woodworking.
http://sawdustmaking.com/
chears
