Nail sets (most trivial tool recommendation thread ever)
dwasifar
Background: Today I was reclaiming a bunch of deck joists. The people who took it down bent the nails over, so I cut them flush with a grinder and drove them out with a nail set, because I had it on hand. Being intended for countersinking finish nails rather than driving framing nails out of two-bys, the nail set is somewhat the worse for wear now, and I need to buy a replacement.
I search Amazon, and they have a bunch of familiar and respected brands like Horusdy, Whlling, Xage, Sedy, and Qwork. Names that everyone knows, right?
For something as simple as a nail set, do you think it matters whether you buy a real brand like Stanley or a fly-by-night make-believe brand like Horusdy? It's not like they don't both come from China anyway.
D
dwasifar
How is it "worse for wear?" The tip? Square it back off with a cutoff disc or grinder.
Well, that would change its gauge, because it's tapered, so I'd have to re-taper it too. And it's mushroomed at the other end. My intention was just to keep this one for this kind of abuse and get another for actual finish nail countersinking.
Let's pretend I don't have one at all, and I'm trying to decide whether to buy a name brand or an Amazon alphabet-soup brand. Do you think it matters?
D
dwasifar
Nail set? what is this tool you speak of? Oh yea, they predated nail guns.
sorry, not intending to be a smart *** . just being an idiot
Yeah, granted I use it a lot less these days. :D Basically only if I'm nailing something I can't use the gun for, or to tap home a nail that's worked its way proud of the surface. Or, occasionally, as a centering punch when drilling wood.
nadogail
Coronado, CA
I have not purchased a Nail Set in the last 40+ years, nor do i recall using one in the last 30+ years. I am so far out of touch with the Nail Set using community, that if I were to go to the store looking for one I would ask the Sales Person who waited on me for a recommendation.
I grab any brand I recognize at a garage sale, but that does you no good. Stanley from any local store should be OK. If Wilde or Mayhew made them, they are probably o k too.
mike93lx
Richmond, VA
I have mostly used a center punch for the applications you listed, but recently caved and bought a set at lowes, craftsman I think. For how little use they will get, my kids will throw them away in 50 years while grumbling about all the **** I have.
Just buy anything
Dave455
Sussex, England
Personally, while there are some things I might economise on, striking tools are not one of them. I used to once, but there’s a very noticeable difference in the quality so I don’t now.
Definitely forget the Amazon specials. Stanley might be better, would have been once, but doubt they are now. I’m generally very disappointed in the quality of Stanley tools.
I’m in the U.K. so my choices might be different, but I’d be happy with any of the following -
Priory - cheapest I’d use. Inexpensive ($4 ish) and perfectly acceptable. British made.0C1B1E14-C8AB-4D42-B6E7-53CB4EDD285C.jpeg
Eclipse. I use these myself. A frac more expensive than Priory, but a slightly better tool. Also British made.037FC01A-3CF3-4EE2-8730-D2920459364F.jpeg
PB Swiss. Comparable money to the Eclipse so good value. Better finished (really nice) but perhaps not so hefty.5678EB84-EB31-4CFA-8729-CE38559F8330.jpeg
Starrett. Very nice, but double the cost of the Eclipse for me.93BCDBB1-40A8-4AAC-8149-A9CBAB37C814.jpeg
KnurledNut
n/a
Once you use a Spring Tools nailset you’ll never want to use a regular one ever again.
When I have to, I use my mini Sharkgrip. They make the best nail pullers too. I’ve pulled thousands of nails and nothing compares to their Japanese engineering across their range of sizes. (With the exception of TOP Japans combo puller bar.)
Most of your better quality pullers copy their profile but none are as good as the original.
billconner
Thousand Islands NYS
I bought a Stanley set a few years back when doing a lot of white oak trim - a lot - and they have been great. Set of 3 - each with a different bright color vinyl sleeve. Easy to find and easy to identify the one I'm using for a particular nail. Just installed a solid wood floor and very helpful for those first and last strips where you can't use floor nailer unimpeded.
jives
Central NY
Couple of years ago I could not find a couple of my nailsets and punches. Decided to treat myself to a new set of punches (okay, so not a nailset) and a couple of new metal chisels. Bought what I thought were quality Mayhew from HD. The centerpunch dulled and the pin punch bent and one of the chisels dulled upon first contact. About the most disappointing tool purchase ever.
m6z
Missouri
I usually use a prybar and a good pair of pliers to remove nails. Have I been doing it wrong this whole time?
Edit: like the one posted above.
Someone knows - that tool for removing nails with a slider on the handle?
The blood blister creator? I have one, and would only use it for wood which I am planning to destroy the working face.
Another decent quality, but not low priced nail set is here. Great for tight clearance.
WWheeler
Middleofnowhere USA
I suspect what you're referring to is just called a nail puller, or 'sure grip' nail puller. Crescent and Bahco still make them, or if you search ebay for 'slide hammer nail puller' you can usually find a vintage one made by Bridgeport, Greenlee, Crescent, etc.
FWIW I sometimes yank nails out of pallets with a vise grip attachment on a slide hammer? OTC sells the slide hammer attachment called a "Grip Wrench Adapter". Perhaps other companies make one too. IDK. Or with a welder it's easy to fab one.
JradM
Alberta
I've got some Stanleys in my tool box, they seem fine. However, were I "in the market", I'd probably look at Dasco.
I've been impressed with their punches and awls, I don't see why a nailset would be much different.
Alternately, with a higher budget, I consider Mayhew to be the top-dog in punches. They've got some slick-looking offerings too:
^ embrace the new technology. stop smashing your fingers.
Noxon / Noxon, Inc. DBA Spring Tools, 2921 No. University, Spokane, WA 99206 (also Spring Line Inc.) / http://springtools.shptron.com/ / est. 1993 / patent 5307741 May 3 1994 & 5426858 Jun 27 1995 & 5433007 Jul 18 1995 Emory J. Clark and Robert J. Warner / TM 86209086 Feb 11 2021 / center punches, nail sets / https://www.spokesman.com/stories/2018/mar/02/inventor-emory-clarks-swring-finds-therapeutic-app/ / https://www.garagejournal.com/forum...inc-emory-j-clark-spokane-wa-01-15-22.492380/ /
^ as near as I have been able to ascertain, this guy is the original. the others are knock-offs of Clark's design.
Dave455
Sussex, England
Historically they were called “case openers” in the U.K, since their original function was to open nailed packing crates. Bahco call them “nail pullers”.
Still an essential tool for electricians here as they remain the best tool to remove nailed floorboards.
billconner
this
Renegade1LI
long island ny
I use a straight pin punch when I need to drive back through, just this weekend had to set a bunch of nails in a new hard floor. I keep a couple sets of these starrett punches, work great.
tarbellb
Oregon
Thread notes:
_Destroying the face of something to pull a nail sometimes (often) is unacceptable in certain trades
_Spring loaded nail setters are awesome
_Quality steel goes a long way in striking tools, buy the best you can afford
_Dasco is typically **** quality, steer clear, same with Stanely
_Dave455 seems to have it figured out, I would take his advice
JradM
Alberta
Really? I've been pretty happy with my Dasco Pro punches. Are there different product lines or a style you were unhappy with?
Or maybe I'm just not discerning enough. 🤷‍♂️ I can't dismiss that possibility!
They are USA-made and offer a lifetime warranty. I didn't find much on GJ. There's this thread on cold chisels.
I wouldn't claim Dasco is the same as Mayhew - but they're probably 1/3 the price in most categories too.
seber
Deep East Tx.
That slider as well as the one you just bang in with a hammer and lever out the nail have always been called cat's paws in my world.
tarbellb
Oregon
Dasco in my experience has been soft, cheap metal geared toward rough masonry work.
You're experience may differ, you have a great selection I'd be interested in your thoughts.
