Naked or stained?
TheClaw
Chicagoland
I realize this is largely personal preference. I'm torn between staining new workbench or just coating it with Laquer. The top is going over double Husky black 46" boxes with a 2x4 frame around it.
I've surfed many of the threads to get ideas and thought I'd hit you all up for your opinion (yes, I know what I'm in for).
Naked lacquer versus stain (color is called Gunstock by Minwax)
Jeff Ivers
Oklahoma
Absolutely whatever floats your boat! Factors to consider - color scheme of shop, show shop or working space, future maintenance. Most workbenches are only going to look pristine once in their life.
PCustoms
VT
I just use whatever shade the cheapest plywood is that day...
Had an OSB bench for 12yrs. When I drip glue and paint and **** on it I run a D/A sander over it and start over
Function over beauty.
tarbellb
Oregon
I missed the part where you e mentioned what species or type of wood???
Pine or Fir, stained always looks the same- hope you like tiger stripes
Oak or Maple, almost a sin to stain
Give some more context, let's admire the workpiece
CraigStu
Blacksburg, Va
The problem w/ stain plus a clear is fixing chips later. The clear soaks in so if you sand through the stain that spot will not take more stain the same as the original bare wood did. So I vote for a clear. I'd probably go w/ Minwax spar varnish because I have used it a lot over the years.
txvwnut
Bedford, Texas
Minwax Gunstock, if you have never applied it has an orange tint over a light colored wood. For a work bench top that's most likely going to get beat up just hit with BLO and move on. Plus as others have stated it's much easier to see small parts and stuff on the lighter color than it is the darker color.
T
TheClaw
Chicagoland
Ok, you guys are starting to convince me to go the BLO route. @MushCreek, you have a good point. Loosing nuts and bolts is common in my shop, that's why I put single stage, light gray, no flakes in my floor.
For @tarbellb, here's progess picture. I'm building a frame around the boxes.
twinfin
Next to the house
So, if going the linseed oil route, watch a couple videos and or read up on tips before you begin. In my experience, I thin the boiled linseed oil up to 50/50 with paint thinner to help that first coat soak into the wood. About 15 minutes after applying, wipe off any excess then give it at least 24 hours to dry, maybe more depending on conditions.
Do a very light sanding after the first coat has a day or two to dry as there will be a some wood fibers that stand up after the first coat. For the second coat, you can apply undiluted but be sure to wipe down excess about 15 minutes after applying and give it plenty of time to dry between coats.
Boiled linseed oil can take a few days to dry between coats; more or less depending on conditions but the end result is always worth the time it takes. I should note that the first coating cut 50/50 with paint thinner will dry faster because of the paint thinner so don’t be surprised when subsequent, undiluted coats take longer.
I’m not an expert by any means but I can’t think of a better coating for a wood surface that’s prone to abuse. you’ve got a nice looking shop coming together and I think you’ll be happy with boiled linseed oil on your bench top.
LopezBart
Lopez Island, WA
Turpentine will work well to thin the BLO and imho smells better; I use BLO, pine tar, turps, and a bit of japan drier on my smaller steamboat (foreground below). I also used this on my black powder pistol's stock. The big advantage is that one can easily renew the finish w/o removing the old stuff, unlike varnish, paint, etc. It is time for more finish in this picture....
tarbellb
Oregon
What are you working with? Looks like Birch??
Good looking top, go clear
My personal favorites are the European Hardening waxes like Woca, Rubio, Bona
Boiled linseed combo is also a strong candidate, or even 1part floor finish like Pallmann or Loba
Cruzan80
Denver, CO
Yup. Things are still fluid in the new shop. I'm not going to nail anything down before I have to so I get the layout close to where I want it.
It occured to me after I posted that it may been propped on the chest, as opposed to rigidly attached. The question came because I thought it was fastened already. Not enough sleep...
Jackfre
N CA
Christopher Schwarz’s “The Workbench Book“ suggests, and having used it I suggest it too, a mixture of thirds of BLO, DNA & Spar Varnish. Dried quickly and easy to reapply. I like Gunstock for a stain color but prefer a bright bench top.
Smilodon
Titusville, FL
Mortar launchers for duck hunting is legal where you come from?
Seriously. Cool old boats. Not sure I'd feel comfortable being that close to a steam engine *I* had anything to do with *AND* on the water, but more power to 'em.
CGT80
IE, SoCal, USA
The clear looks good and I did the same on some of mine. My new ones are mdf fornthe clean bench and osb where I grind and weld at a vise, for things that don't get done on the precision fabrication table. light gray paint looks good and can be applied again....they need it now, after a couple years of use.
Another cabinet I built is a tall bench with an oak plywood top and 9 drawers. It is stained red oak and has a high end lacquer clear. It holds add a bins and parts. Being chest height makes it nice for looking at smaller parts. It doesn't get beat up so it still looks good for a garage bench.
T
TheClaw
Chicagoland
I'm letting the BLO cure this week. Any downsides to a few coats of clear lacquer (with the exception of the ability to repair a small area now and then)?
cgrutt
I'd just leave it alone for a workbench. Not sure if you will have any adhesion issues with lacquer may want to look into an oil based product such as polyurethane or varnish. That BLO will likely need a few weeks before fully curing. Wax also works over BLO.
T
TheClaw
Chicagoland
Wow, that looks great! Get a roll of cardboard to top it.
Thanks! I put some hardboard on my old butcher block workbench because the top looked so nice. With the hardboard there I never saw the nice butcherblock. May as well use OSB.
I'm thinking I'll put some oil based poly on there to protect it and just give it a re-fresh every couple of years. Most of my work there is motorcycle and car related so there's going to be grease and oil.
