Name of this Starrett tool
swinz
Derby, UK.
Hi i have seen this Starrett tool listed for sale on a Facebook group. I believe it is used for cutting washers from leather or other types of sheet material, can anyone give any other details or the correct name of it?
Im not thinking of buying it but thinking of making something similar at some time to help with the cutting out of gaskets.
Mintgrun
Kingston, Wa.
I had heard them called gasket cutters. Very useful tool in my shop. Mine is not made by Starrett though. That is a nice example.
Tom
Provincial
Near Salem, OR
swinz, if you find an Allpax gasket cutter that is complete, it is the nicest one I have ever found. It is easy to use and packs up in a compact metal box. You do not need a machine to operate it, as it is all self-contained. All you need is some sort of backing so the blade doesn't contact your work surface.
I found mine at an estate sale for cheap. They are on Ebay for more, and Allpax still sells a similar kit.
Link to Ebay Photo
Can you show a picture of the Starrett name?
I can see parts of a stamp on the main body, but it’s somethingFIELD, MASS.
green, spring, pitts, mans, and maybe more are all options
Mintgrun
Kingston, Wa.
Nice work, RTM. Googled Greenfield Mass vintage gasket cutter and some came up that look just like it. Made by Goodell Pratt.
I'd have to look at mine again, but based on the image search results, mine was made by them as well. (Googled image, not mine).
I often use mine without the brace, but having that option is very nice, if I have many pieces to cut. It's a fun tool to use.
Tom
Mallen
You know, I just decided I want a Cricut cutter. I could use it to cut complex gaskets.
swinz
Derby, UK.
Thank you gentlemen for all your replies, obviously the vendor got the manufacturer wrong but with the vast knowledge of all the contributors on here we got the correct tool name and correct manufacturer.
Thanks again Paul.
