Name that fastener!
blarf
The hose clamps on the BMW's fuel filter use these insidious things. Subtract the ten odd years of grime and that's how it looked from the factory (or so everyone else seems to claim). Hose clamps being as cheap as they are I replaced them already, but... what *is* that.
haloghalog
DFW
That's a Norma hose clamp, excellent quality and rolled edges so it won't cut into the rubber. The cheap ones you can pick up anywhere have too much play in the screw and could possibly loosen over time, plus they will cut into softer rubber.
mrholeshot
MEMBER EMERITUS
You are just messing with us right?? What tool is needed to install the technilogical marvel?
blarf
Okay, what's used to tighten it? With only two flats, a socket doesn't work particularly well and a slotted screwdriver slips out.
AustinRoepke
Not Chicago, Illinois
I might be making a fundamental error, but I'm pretty sure you pull on the free end, then tighten the screw down, locking it in place.
How did you get it off without letting the screw out?
blarf
Take a look at the head. You can use a slotted screwdriver to loosen but not tighten it.
blarf
Is the right answer. (Locking pliers work too!)
AST make one, and there's a BMW factory tool too. Samstag have one on their site.
Ahhh serves me right for not digging through the Samstag page. Any idea what the AST one is called or if there's a proper name for that type of screw?
Locking pliers worked well enough on the Volvo struts that have a similar bit up top, but were a non-starter on the fuel filter. Being under the car inhaling gasoline vapor means I want to get out of there ASAP.
Moose-LandTran
The Brink of Insanity (England)
That hose clamp is exclusive to BMW.
AST tool number is BMW 075:
http://www.asttool.com/detail_page....offset=27&stype=bymanf&manf=BMW&category=spec
The Volvo shock piston is just the round end with two sides milled off, usually a 6/7/8mm open end wrench will hold it fine, Snap-on make a 6x8mm oval socket for that too though.
