Need a handle made or a source for new
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Well when I bought my 6" Craftsman lathe, the handle for the cross slide was broke. The handles are made out of potmetal. I ended up finding a complete saddle and compound on EBay with all of the handles. When I received it and unboxed it, the handle I needed was broke:scared::mad: To buy one is anywhere from $55 to $145.
If I sent one of the old handles to someone that is set up for machining, could someone make it for a reasonable price. I don't mind being fair, but for what the handle is, it's not worth the price they are commanding for them. I'd rather have a handle made out of steel, or if you have the means to chuck it up and screw the old handle to the old base to put it back together, that would also work. I just am not set up with a mill or a drill press to get the holes in where they should be.
This is the handle I need repaired or replaced
Larger view. What breaks is the handle coming out of the smaller ball. I'm thinking that there is a demand for then due to the high cost. BTW...the one shown is going for $64,95 on EvilBay :mad:
bad_idea
Pasquotank, NC
Re: Need a handle made or a souce for new
Sorry to say racingtadpole is probably right. Unless someone rogers up and does it as a favor, that handle is going to cost more in time than what evilbay is asking.
joshuaz223
Central Square, NY
making it exactly the same is a lot of work making it really close is possible. if your interested pm me and i will give you my address. i would do it for pepsi money and shipping.
lametec
The handle is most likely threaded into the ball. Unscrew the broken piece, then buy a new handle to screw back in. Enco has 'em.
If they're not threaded, drill and tap, then thread one in.
http://www.use-enco.com/CGI/INPDFF?PMPAGE=688
My cross slide handwheel was missing both handles. I drilled out the holes and press fit new handles from Enco. The reason I press fit them was that they stuck out too far for my taste when simply threaded in. So I cut off the threads and pressed them in instead.
K
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I looked all thru Enco's catalof this morning and didn't find anything like that. I'll have to measure what I have now to see if it will work.
If not, then joshuaz223 I'll be getting in touch with you.
Kevin
Alchymist
Central PA
You have a lathe ......seems a reasonable substitute could be done on a lathe, though a small mill would obviously help. Does it really need to be chrome plated? The handles on my South Bend aren't.
K
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Kevin
WILD-BILL
Brook Park Oh
I have the same lathe and had the same issue, broken handle. I just bite the bullet and bought one.
What I can tell you is these are IIRC a 5/25 shaft with a key way. The nut you see pictured in your first post has a slight taper to it and a matching taper on the handle. When its installed, the outer nut is tightened in then another locking nut is tightened from the carriage side of the the screw. There is no exposed thread outside the handle so getting some aftermarket handle and fabbing it on may not happen
K
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I really hate to bite the bullet and buy one that is expensive. I thought I lucked out when I bought the complete saddle with all three handles, but by the time I got it out of the box, it was broken. And as I said, I'm not blaming the seller. The saddle was in a box and it was wrapped in shipping paper. If the box got tossed around any, I could see where it would break. I can make one if I had a mill, but all I have is a lathe so far. I'll keep looking around, but may have to take joshuaz223 up on his offer. I can make most of it, but will need to have a little more work done. Later on I may have to get some castings made and sell them myself as it seems that everyone that has the Craftsman/Atlas/Dunlap lathe has the cross slide handle broke. One guy was selling three castings on Ebay I believe for something like $175. For that kind of money, I'd try to make handles all day long
K
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Thanks guys. One of those places are bound to work. I'll take one off today and measure it and let you know.
Thanks again!!!!
mike13u
S.Florida
I will second Reid Supply for stuff like that. Order a print catalog and keep it in your shop. It is a great reference.
trainer
Northern Ontario, Canada
this!
From wikipedia;http://en.wikipedia.org/wiki/Turning
"It is said that the lathe is the only machine tool that can reproduce itself"
rsanter
visalia ca
I had the same problem with the ball part that has the handle in it broke off.
Fix
The handle is pressed into the ball. Clamp the ball in a vise and drill a small hole on the back side of the ball. Take a punch and knock the handle out
Take the handle off the lathe and drill a hole in the other ball on the handle...use the broken off one as a guide as to what size hole to drill.
Tap the handle piece into the handle and reinstall on the lathe
Now get a piece of aluminum and machine a new handle. Polish the aluminum, no need for plating
Bob
larry4406
Northern Virginia
ProGun3400
Will County, Illinois
I was just in the shed & came across a cross slide apron from an old Craftsman lathe that I no longer have. The pictures posted above are not viewable, not certain if we are all speaking of same part??
larry4406
Northern Virginia
I couldn't see Kevin's original pictures either, thus I posted a picture in my Post 19 of what I need.
I am interested if yours matches.
