Need a long 1/4 drive breaker bar
mreisner
North of Detroit
The Vim stuff is pretty good, could you use it and reduce the size of the handle some like on a belt sander or for that matter just pop it off they're just pressed on?
Viper98912
GA
Trying to read between the lines of your replies, it looks like you need to fish a very thin bar through a very tight space that doesn't allow you to have very much range of motion to turn the socket. So given that a specially created tool just for this is necessary, but the fact that it'll take you a very long time to make this special tool, I recommend:
1) Drill an access hole, do your work, and plug it afterward
2) Start disassembling.
Ohio Andy
Columbus, Ohio
Tekton and gear wrench have a 9" ratchet.
SK has an LP90 model 80182 that is 12" long. Zoro sells it for under $100
Vim breaker bar is 10" long (IBB410)
No name flex ratchet. Extra Long Flexible Head Ratchet 1/4" inch Drive w/ 11" inch Long Handle
Damon L.
SE Minnesota
I have an old SK 1/2" breaker bar in my toolbox that has a female 1/2" square in the end of the handle, allowing me to add a second breaker bar as an extension.
Seems to me that if you could find this configuration in 1/4" you would be golden.
GCS
Oklahoma
Here’s a few options if your size is available…
Etchase
Hawaii
One of the many low profile sockets with a 11mm hex head end and a flex head wrench? The Gearwrench 12 inch ratchet above is as thin as a flex handle socket driver. What fastener are you driving?
Steve_P
A 1/4 Matco 88 or Gearwrench 90 has a lower "head height" than a Williams USA breaker bar. This is true in all three drive sizes with either Williams USA and/or SK USA breaker bars. If the width of the head is an issue, then ok, breaker bar. Modern ratchets have basically made breaker bars obsolete, so there isn't much attention paid to them anymore.
FigN⋅m
Was thinking the Tekton version - looked to see if their old 6 pt. model was still on clearance, but it's new only.
Stick (magnetize?) a 1/4" hex to 1/4" square drive in there and off you go!
cosmokenney
Loyalton, CA
Sounds like a woman's book club conversation that took a bit of a turn...
What is the longest out there?
Not looking to use cheater pipes, extension adapters or anything like that. I seek a ONE-PIECE breaker bar, 1/4 inch drive, and long.
How long? Well, longer is better. Ideally, 10 inches plus.
Why do I seek this? It's complicated and I'd rather not do all the explaining. But it has to be as described above and all I can find so far is 6 inch long breaker bars in 1/4 inch drive.
11" of blue wonder...
@Dave455 mentioned having a long breaker in this thread.
The only thing in 1/4” still cataloged that is 10 plus is the snap on TLLF72 but it’s not a breaker bar.
Why not ? Probably needs to get into some crazy spot where anything with an adapter would be too thick ? I have had a few times over the years where I wish I had one.
10 inches long, made by VIM, 1/4 inch drive
The longest I found is a 7.8 inch long one
Snap-on TM9G is 9" long. I guess they're not made anymore.
2ndGearRubber
Pittsburgh
Astro 91410 is a 1/4 ratchet. 12" long, but with a tiny head. It held 50ft/lb for me while torquing a strut today. Head is not much bigger than a breaker bar.
mikey03
I got four ideas for you
snap on XL 0 degree wrench which has a lip on it that extends out.
the 10 mm is 10” long so idk what size socket you were going to use but the 12 and 13 and 14 mm are even longer
Or get you a dual drive socket like one of these from snap on
and put it inside a 11 mm XL box end wrench like the kind I just linked or maybe you got one already.
or get a ratcheting wrench adapter like this and put it in an XL 10 mm box end wrench
or get a cheap breaker bar anvil and pay someone to weld a steel rod to it
Vvmvbb
CT
firebox40dash5
I've long had the bad habit of trying to "save time" by doing things in ways that end up taking a lot more time.
I can't see what OP's working on, but this sounds an awful lot like that. Maybe I'm wrong. Maybe once it's apart (hours of painstakingly working around obstacles later) you find out you really can't get it back together the way it sits.
KnurledNut
n/a
Can't find that on the snap on site though. Maybe it's discontinued and that's why they are charging so much. Rarity and so on, more money blah blah.
Thats because that is a flex head ratchet someone swapped to a breaker bar head.
haveissues
Hudson Valley NY
Sounds like this is a one use kind of tool. If you can't weld find someone that can, it will take 5 minutes.
Take a piece of stock whatever length you want and weld a piece of 1/4 extension at whatever angle you need. You could even weld on a socket and make it even more compact. Or sacrifice a gearwrench ratcheting wrench.
cherrybomb
Near Madison Wi.
I'm late to the party,members as always have many good solutions.I would of liked some pictures by the OP,always a better understanding of the problem and a quicker,working response by our team
MovingAlong
OP is definitely in a spiral and I can empathize. To focused on "I need exactly this..." to value a fresh perspective from the 10,000 hrs of problem solving that the average GJ member brings to the table. :dunno:
I've got a piece of 1" x 1/8" flat stock about 24" long with a cut off tip from a 3/8" extension welded on. Only 1/2" thick or so total, very nice for releasing tensioner pullies in tight areas. The best specialty tools are the custom ones made in the shop - purpose built. :thumbup:
NUTTSGT
Northern Central Ohio
Pictures always help.
I know Masterforce from Menards has a 10.25 long flex head ratchet in 1/4" drive.
username2
The problem is that asking for a specific thing, particularly on a website oriented this way, will always result in a cacophony of 'WHY DO YOU WANT TO DO THAT FOR! (with a 'you dummy' in the undertone). People simply can't help it, it's baked into the cake of male humanity. Some folks are simply unable to answer the question as posed.
It is funny how the closest thing to a long breaker bar looks to be a long ratchet, the thing the breaker bar is supposed to save. Given how strong ratchets appear to be on YouTube tests, I wonder sometimes if any but the very largest breaker bars have any value at all.
(on a related note) I've decided lately that 1/4" sockets are pretty cool and wonder what the failure point is. If you take a 5/8" quarter inch drive socket and a good ratchet and push hard, what goes first and at what torque level?
Dixie_Flatline
Tennessee
I used my 1/4 drive and an old Craftsman bolt extractor on a stuck exhaust manifold stud. Put a wrench on the ratchet as a cheater and it snapped the extractor off. Stuck the remaining bit back into the socket and gave it another go, this time removing the stud. I had very little room to work with, a breaker bar or a longer ratchet wouldn't fit into the space, so the 1/4 drive got to be torture tested.
richfinn
Leeds, Yorkshire, England
It's a discussion FORUM, people are going to ask questions, challenge other people's ideas and debate topics, that's how it works.
The OP already knows the answer to his question and has a history of asking odd questions/making ludicrous statements to stir up trouble hence the challenges from other members.
Can't tell us what the application is?
Has previously stated SNAP-ON should be the only option (but can't locate the tool himself)?
But has plenty of time to question perfectly reasonable suggestions like the VIM breaker bar?
He now has you questioning the validity of breaker bars altogether?
It's nonsense 😉
username2
If I had said that, I apologize. What I think I said was that perhaps *small* breaker bars are less valuable since ratchets appear to be stronger than I expected. Thank you for your well-meant input.
richfinn
You are 100% right to question things, my post was more of a heads up not to get sucked into his trolling nonsense (I've Been There Done That) 😉
The Bean
Delaware Valley (SE PA)
I was thinking the whole thing was a joke or a scam just to get the GJ membership riled up. There is no special application. He left the chat days ago. End this thread.
IBTL
