sorensen1987
What is a good reliable brand that won't break the bank? SPI? Fowler?
But verniers are a lot handier.
I'm going to be using them for motorcycle measurements. Pistons, cylinders, valves, etc.
http://harleytechtalk.org/htt/index.php?topic=43362.0
I'm attaching the above link to help frame the the response below.
If the OP is asking for a 'good' mic then it is obvious to me that he has little to no experience is using one or what the readings may mean. The above link is a discussion on lifter clearances in a HD motor. They are talking in the .0008" clearances range. Your not going to determine these numbers with a standard .001" mic, and damn sure not with a sliding caliper.
So Op your going to have to figure out what your doing with the micrometer tool you want. To what tolerance are you working and the tool needed to achieve what you want. Its one thing to measure something to determine if it is a 3.85" diameter vs a 3.95" diameter. It is a whole different league to determine if something is 3.8503 vs 3.8506. Where are you in this spectrum? Post #4 above talks about ordering lifters that are oversized by .0002" increments. For you to determine what size you may need is going to take something of a bit higher level that you are wanting, as well as a clean temperature controlled shop.
Good luck on your endeavor. Been there done that and I have determined some things are better left to the experts even though I think I may be one.
lg
no neat sig line
I know that I'm no expert. And I don't go around saying I am. I'm trying to learn. I'm currently attending MMI (motorcycle mechanics institute) all I'm trying to do is get a set of decent micrometers that are fairly accurate to practice using them and get efficient enough to where I feel comfortable. I have over a year left of school, so I won't be measuring cylinders or any parts for that matter in quite some time. Thanks for your help buddy.
OP said he'd have to wait and he has nothing to trade.
$299.00 list price
I'll take $110 shipped or interesting trades.
I am looking g for a small, like a chrome and black from an old all state, traditional tear - drop tank.
It is to use as the gear cap on a camel back drill press like the pan on the top of a modern drill press. If you can think of anything better than the tank, I'm open for suggestions.
Any interesting trade, dollar amounts do not need to match.
Brown and Sharpe, non slant.
That and Verniers can be difficult to read. Precisely why they started making them with dial and/or digital read outs. Calipers are more susceptible to chip and grit damage as well.Verniers may be handier, but verniers are not accurate if you have to work with close tolerances. Verniers are a reference only piece of equipment
As far as mics, Starrett, B&S, Mitutoyo, Fowler. You can get used ones, but make sure you get a "standard" to check them. Also try to find a pair with carbide tips. What size are you looking for, as I may have a spare I may sell for a reasonable price.
Yes they can. Maybe it's just the tool & die machinist in me. Learning to calibrate should be micrometer 101. And each should come with a spanner wrench.I have standards [some do not exactly fit civilization as we know it].
I've not had anything out of spec. Can these be adjusted at home?
I can't imagine the thread count on the set screw that does that [actually I can't imagine how it holds at all and is adjustable]
I recommend Starrett 436 used on eBay. These aren't Starrett's best models. But they have been essentially unchanged for 100 years. I like them because they are very easy to read. I find Starrett's markings to be the best in the industry. Even now, nobody makes a ruler as easy to read as Starrett. You can pay $25 or less for a used S#436.
I see no advantage in buying new second quality mics when high quality used miss are available cheaper. Yes you will need standards for the sizes over 1" Mitutoyo stds come up on eBay quite often and can be recommended.
Sounds like you have time. Start searching eBay for the old Starretts. There are instructions on the web about how to disassemble, clean, lube and adjust them.
If you want the very best, most accurate and easiest to use, get the Mitutoyo digitals. Advantage for what you are doing is being able to switch between inch and mm and also checking the axes of a cylinder. You check on axis, ignore the reading and zero the mic, then check the other axis (or axes) and the mic reads the difference (e.g. -.00200" indicating you are oval by .002". This saves you some math.
You will need a 3-4", you may need a 2-3" depending on your engine.
You cannot precisely measure things with calipers just due to the design of them. Just a little bit of thumb pressure can change them by .002 VERY easily.
Post a picture and length height width.
It doesn't have to be chrome. I was referencing a small bike with a cool enough tank.
And it doesn't have to be a tank. I just traded anew bluepoint digital caliper for a worthless unusable fire extinguisher offered up by the other guy.
