Need an electrolysis power supply
Those are typically very low amperage. Probably not a good choice. Also many recent are higher voltage than is desirable. The newer ones are also solid state which can present other problems.
Leviton
Oregon
Actually, there is a way around that someone posted:
Use the new type battery charger AND a battery. The battery keeps the thing running and provides a more stable current through the E tank.
:3gears:
When you do this, are you connecting the battery in parallel or series?
Thanks.
