Need help finding a cap....
pbkelley
Powder Springs, GA
I have a natural spring under my house and the previous owner installed a sump in the basement using a piece of 24" metal corrugated pipe surrounded by concrete. He was using a piece of plywood to cover the hole and for obvious reasons (wood absorbs moisture and mold grows), I would like to find something a little more substantial.
I found a company called polylok that makes a cover for plastic pipe - https://drainagedirect.com/24-heavy...MIsM6fj7GJ4gIV3LfACh3pNgTaEAQYAiABEgKoHPD_BwE
Since this board and it's members know everything, is there something else to cap the hole? The sump has a drain pipe going out the side of the house and it does not require pumping. As long as I see a dribble of water outside, I dont have any need to open the lid. The lid doesn't have to be a perfect seal - but enough to cut down the moisture in the basement and keep out any critters that travel inside using the pipe.
Thanks in advance for all the help and suggestions.
Stuart in MN
Minneapolis
How about the lid off a plastic garbage can? You'd have to go measure cans at the store to find one that has a lid 24" in diameter, but it would be less expensive than the Polylok one in the link and you'd still have the can itself for other uses.
rlitman
Long Island
I'd start with plywood. Then prime it in oil based primer (or any primer that's ok on wood), and top with a gloss latex paint that has had mildewcide added (indoor/outdoor latex would work too).
It's not sitting under water. There's no real need for plastic here. And a trash can lid doesn't protect from someone falling in.
fasteddie
I would go with the secure sturdy lid in your link. For $50 just order it and slap it on, the price seems worth it to me.
EOC_Jason
Bentonville, AR
I'm sure there has to be companies local in your area that sell septic tanks & supplies. You should be able to get a cap and whatever else you need for much less than that online price.
engineer2
Chicago burbs
The challenge is to find a lid that has a 24" diameter. An alternative is to have a local shop cut you a steel cover in the exact size you need.
Leaflessshadetree
Don't ask.
I've seen one that the homeowner made of concrete. It was about 3-4" thick around the edges tapered sides and had rebar "handles".
BillK
Beautiful Southern Maryland
I agree with the others. For $50 you cant go wrong buying a lid that is made exactly for your purpose. I suppose you could run around and check Tractor Supply or some other places and you might find something for a few bucks less but why waste the gas ?
