Need help finding exhaust flange
1upmoto
Im building a header for my zx10 and I ordered some standard 2 bolt flanges but they are way too thick. I can make them work but I dont have much thread left on the studs. I heave searched google and can not find what I am looking for. The tubing it 1.75 and I am looking for some stamped 2 bolt flanges similar to these pictured.
Untitled by 1upmoto, on Flickr
1upmoto
ive thought about that but to do it the way I want it would work best with a thinner flange, its a very tight bend right off of the head.
dogdog
if you are that much strapped for room, consider use v-band clamps ?
1upmoto
I cant use a vband in this application.
Thinner will be more prone to warping and leaking.
here is what I am working with, the flange does not seal it just holds the pipe against the head which is the sealing portion. But I just ordered some studs, seems like the easiest option at this point.
dogdog
looks like a nice project. post more pics of the progress please.
scott0
Frederick, MD
I spy supermoto?
Why not cut the original header and use the stock flanges? That's what I did for a 636 turbo manifold.
bad_idea
Pasquotank, NC
The pipe may be the sealing point, but the flange provides the clamping force evenly across the entire pipe. A thinner flange will only apply force on the two sides by the bolts and bow outward in the middle. I think longer studs is the right answer.
kerrynzl
Tauranga, New Zealand
Turn it around 180 degrees and bolt it in from the inside of the flange
1upmoto
^^^^THIS^^^^
You have your flange on backwards. The two outer lips go towards the outside and not towards the block.
I don't have anything backwards, that is a pic of the factory flange on the factory header lol.
