Need help identifying this tool/part?
Dangie
Attached
Hi All,
Just joined and this is my first post and not sure I am in the right place! If not I apologize!
I am asking for help to identify this tool/part in the photo! It is heavy.
Thanks
Dangie
D
Dangie
Attached
No, about 3/4” of fine threads at large opening.
Note the removable stud has a sharp point that goes inside the cylinder!
Thanks,
Dennis
shanny19
PNW
If I owned it, i would use that and a vise for rescuing the fluids from my aerosol cans that held fluid still but no gas.
Might build one.
No clue what it really is.
D
Dangie
Attached
It has a pretty heavy weld around the nut where the pointed bolt screws into so what ever it screws into must be under some high pressure!
Dangie
D
Dangie
Attached
I think it must be for something else since the bolts pointed end must be for piercing something?
Dangie
D
Dangie
Attached
Also an internet search shows the motorcycle flywheel puller has threads on the outside and these threads are on the inside?
Dangie
gungatim
west mich
flywheel puller for a motorcycle. I have a similar although smaller version for pulling the clutch cover on dirt bikes.
my vote as well. small engine hub puller, pulley/clutch puller for large AC unit, etc. I have a dozen or so for various things and some are internally threaded, some externally, some have both. always fine thread like that.
look for a part #, it may be for something like a diesel truck, construction equipment, or who knows.
I picked one up for a buck at the flea market just because it said snap-on, ran the #'s and it was a GM ac clutch puller...which I actually needed...bonus!
larry_g
oregon
What is the pointed bolt for?
Thanks,
Dangie
In machining shafts a lot of them are "turned between centers'. So before a machining process on the shaft is started it is center drilled. So google center drill and turning between centers.
lg
no neat sig line
2oolhound
BC Canada
As stated above most cam shafts, crank shafts, transmission main and lay shafts etc are made on a lathe or dedicated grinding machine by turning the shaft between centers. To make the shafts center, a tapered hole is drilled into each end so the shaft centers itself on these machines during the grinding process. That way all the areas machined on the shaft are on the same center. Gears located on these shafts once in the engines, transmissions etc. are an interference fit so there is absolutely no play as these components must spin at high rates of speed and bear tremendous loads. The pointed screws locate in these center drilled shafts so the threads in the large outer piece are also kept centered during removal of these gears during rebuilding or repair work. Because of the interference fit pullers must be very strong to remove these components.
Here is a motorcycle cam gear puller similar to yours:
D
Dangie
Attached
Thank you all for your detailed explanations and photos. Since there are no markings on the tool I was hoping to identify its particular use so I could sell it. However there are apparently to many uses and styles to nail it down to its particular use.
Thanks again for your help! At least now I know why it is!
Dangie
D
Dangie
Attached
I have another tool I need help identifying. I have attached photos. It is approximately 6" in diameter.
Thanks
unslow1
Illinois
You will probably have to start a new thread. People will assume this is asking about the previous tool and not bother to open this. I did a first then got curious as to what you would've added.
