Need help Identifying three tools
Boiler
Indiana
I've got 3 tools I can't identify and would love any help you guys might have for me.
#1 Snap On S-9831 (1953 date code). about 12" long
#2 SNAP-ON TOOLS CORP (no other markings) Photos show each end in detail
#3 Borroughs Quality, Kalamazoo MI - BT-3565. Photos show different arm positions and how they affect the tool underneath.
Boiler
Indiana
/bump
Nobody? I figure the first is some sort of belt tensioner or something?
mtnkrake
The first one looks like some sort of flywheel/flexplate turner.
larry_g
oregon
I have your #2 tool that I was going to post as a whatzit. It came from my FIL who was a diesel mechanic in the late 50's to the 70's. So I assume it is some diesel related tool. Mine has a patent number on it.
lg
no neat sig line
Bruce Lancaster
Agree that #1 is flywheel engine turner, #2 is for sure an ignition point tool (what was that diesel guy doing with it??) used for aligning points after installation. Essentially a small bending tool fit heads to grip various parts of point arms. Want both if you're gonna sellem! No idea on #3.
larry_g
oregon
http://pzphotosan111-r.blogspot.com/
My tool is branded Allen but the patent number led me to the above page that is what mine looks like. Note that the ribbed piece will slide over the notch in the end of the arm. As far as a diesel mechanic having one it would be for the pony motor on the early Cat engines as well as for the mag or distributor on the TD series International motors. For those who do not know the TD series motors started on gas and then when warm you switched to running on diesel.
lg
no neat sig line
Milton Shaw
First is a flywheel holder/turner. 2nd is a point adjusting tool and I have one, 3rd looks like something to bend wire or spring into a right angle. haven't seen anything like it.
Boiler
Indiana
I think you're right. I think #3 is for bending some small piece of metal anyway.
Thanks guys for all the help!
Boiler
Indiana
Yes it looks like it is spelled Borroughs. I've had other Borroughs tools before, but I can't find **** about them now for some reason. The only thing solid I found on google was my own old ebay auction, in which case I spelled it Burroughs....
Boiler
Indiana
Borroughs made a lot of specialty sockets from what I've seen. Their sockets are called out in some install and repair instructions from what I've seen too. I get their stuff about as often as I get Kent Moore tools.
Bruce Lancaster
I think they supplied GM at one time. I believe I have some early 1950's carb tools for various Oldsmobiles and Pontiacs.
Boiler
Indiana
Yep, I've had several oval sockets from them and a bunch of prong sockets.
Wrenches of Death
A red state.
Man, it hasn't been THAT long since ignition points were still state of the art. :)
The second tool is an ignition points adjustment tool. It was used to tweak the arm and the base so that the contacts are exactly parallel and centered. I've still got a couple of variants around here in my tool box. I actually used one last year. One of mine is made for the "t" profile breaker arms.
The third tool looks like it might be for adjusting (by bending) the linkages of choke pull offs and vacuum breaks on carburetors.
Hope this helps.
WoD
usdemt
South Dakota
Number 3 looks like it would work to bend cotter pins, nothing to base this off of, and I cant tell size, but I could see it being used for that.
