Need help with an older RamAir 80 gallon compressor
Kgiall
I picked up this 1987 RamAir 80 galllon air compressor for next to nothing this morning. I was told it has some oil blow by in the lines and they decided to upgrade to a new system. I have not been able to find much information on this brand, other than another post on this website that hints that it might have a Campbell Haus pump. The thing I am confused about are the motor is directly connected to the pump, most compressors use a belt sytem. Is it worth trying to rebuild the pump if I can get the correct parts? Or am I better off converting it to a newer pump and motor?
mike93lx
Richmond, VA
Direct drive? I bet it's loud as hell and doesn't perform great.
If the tank is good, I'd look for a new pump and motor setup
The Cobbler
oil blow by would indicate likely bad rings. it could be as simple as someone overfilled it with oil on a service too.
If it was me, I would check it over before committing to anything.
if parts are available, and not too pricey, I would invest in rings if that's what it needs. that's assuming you are Ok with a loudish air compressor, and it will serve what you need of it.
K
Kgiall
Thanks for the replies. So far I've put together that its the same pump and motor used on the 1988 Speedaire 5Z017B with the motor being a doeer LR13758. I am still trying to find parts for this pump using the Speedaire as my basis for information
K
Kgiall
I'm going to call grainer tomorrow since their house brand is Speedaire. I learned the motor and pump are sold as a unit via the parts diagram I found on the parts website. Only bad thing is they don't have a link to that part or ref any part number for it
K
Kgiall
Last update to help the next person. If you have one of these Direct drive RamAir air compressors you might have luck looking for Speedaire 5Z017B parts, I did not howevver have any luck. I dis however get lucky and found that the Campbell Hausfeld HS4810 apears to be the same pump with a remote motor like the newer ones you see today. The pump cyclinders, bolts and front plastics all matchup as well from the photos i could find. Parts seem to be available online which is a huge plug. Hopefully someone else will find this useful later on down the road.
