Need help with Rockwell bench grinder model 1053
rsh1950
I am new to the forum as of today. The reason for joining is that my friend gave me this Rockwell bench grinder model 1053 (motor is made by Marathon). There is a reason why he gave it to me and this is because someone in his shop dropped it and the shaft must be bent. I am just in the tear down investigation stage and this is where I need some help. I have the grinder wheel cover off and the grinder wheel off (It screws on).
Here is where I need the help. I don't know what the collar on the inboard side of the grinder wheel called but I can not get the thing off. It moves about a 1/2 " back and forth but it will not slide off the shaft. Do I need a small puller to get it off?? I really would like to salvage this nice old tool.
I look forward to your reply.
rsh1950
I would have attached a couple of pics, but I don't have a URL# that it asked for.
exmaxima1
Midwest
rsh1950
That is an inner flange for the wheel and it is keyed and very tight fit. They are still available but cost $68 each. It goes about an inch into the end bell. If the shaft is bent, it will take a puller (at the very least) to remove it. Don't be surprised if you ruin it.
I think your grinder looks like mine.
R
rsh1950
Your information is very helpful. I did not see a key and I thought I was looking very close, however I will take another look.
Thanks again for you quick reply.
rsh1950
exmaxima1
Midwest
rsh1950
The "key" is a cross pin in the shaft. There are notches in the flange piece that engage the cross pin to keep it from spinning. Once you pull the flange out a bit it should be able to turn on the shaft.
R
rsh1950
exmaxima1
I never found the cross pin and I gave up and dropped off the grinder at a repair shop. For $30 dollars they will take a look and tell my what it will cost to fix it. I should know in a couple of weeks and I will let you know what they found.
thanks
rsh1950 (as in 1950 Ford)
