Dr Disturbed
Hi!
I would like to have recommandation or opinion on my projet. The projet is a detaced garage to work on car and other side projet.
I want to have 3 bays, or zone if you like.
Bay 1 will be use to wash or park car. So a clean area without any tools exept detailling tool like shop vac, electric pressure washer and cabinet to store product.
Bay 2 will be use to work on car and I want to have enough space for a 2 post lift and a tool box and couple cabinet.
Bay 3 will be use for bigger equipement like powder coat cabinet and oven, drill press, hydraulic press, welding equipement, etc
In my opinion, a 30x45 (30X15 per bay) garage will be the perfect size with 12 feet high wall for the clearance of the lift. But I would like to have some storage space. My plan will be to use attic truss.
So here are my questions:
Do you think that size would fit my need?
How thick the slab need to be for a 2 post lift rated for 10 000 pounds?Should I make the slab the same thickness all around or thicker where the lift gonna be?
Does 12 feets high is enough to work underneath a medium size car without bending?
Should I pay to get the radiant heating system in the slab, is it worth it?
Picture or opinion is welcome
Keep in mind that the whole garage need to be isolated since the temperature can be anywhere from -30 to 90 fahrenheit.
Thank you in advance.
