Need some help getting into a Salzer Momentary Switch to get it off a Fenner Fluid Power Unit.
Busted_Knuckles
Northwest Illinois
Im swapping out a 3 phase motor for a 1 Phase for my 2 post lift, the new motor, has no switching on it, so I wanted to move this nice momentary switch off the OE pump's 3 phase motor and onto the new Chicom POS.
I cant get the shroud off this thing, because I dont know where or how its " clipped " or attached. I have fiddled with it for near a half hour, googled it, nadda, I dont want to break it, because its a nice switch and exactly what I need... I can see, that once I get the yellow top piece off, there are 4 screws holding the switch to the steel cover off the old motor, just need to know how to get the yellow " hood " off this thing without breaking it.
Ive completely molested this thing to the point of breakage with a screw driver, and cant find the sweet spot to get it to release...
Anyone ?
Thanks in advance !
Switch may not be rated for a single phase motor.
Switches have higher rating on 3 phase...
Is there a make and model for the switch?
Busted_Knuckles
Northwest Illinois
Thanks for catching that, wasnt thinking about amps...
Salzer
M225-SE1648
634681
Looks like it will run 23 amps
Im wanting to run a 2hp motor on single phase.
that 23a rating is for 380-440v
regardless we need the HP ratings.
ive been searching for the product sheet for the switch but cant find it.
what voltage is the motor that was on there?
Busted_Knuckles
Northwest Illinois
208-230V 3ph
Says it should pull 6.3 Amps
Im aware that 6.3 Amps 3 phase is not the same for single phase, but I also dont know the math conversion.
I wonder if there is no spec sheet, because it might be a contract item ?
Busted_Knuckles
Northwest Illinois
New motor is blue old motor is black, looking like I got a " winner " here if I understand things correctly... I need 14.5, and Im allow 17amps ?
Busted_Knuckles
Northwest Illinois
Can you not remove the red knob first?
Its captured under a lip 360 degrees around, I tried to remove it like getting a tire off a rim, also I tried prying it up and off with no luck, allot of other similar switches like this, has screws, not sure on this one...
again, for a motor rated switch, you need to look at HP ratings NOT amp ratings.
are you running this @ 240v or 120v?
if 240v, then youre good to go as max HP @ 240v is 3HP but....
if youre running it at 120v, then its a no go, since the motor is 2HP and max HP @ 120v is 1.5HP... sounds like youre running it at 240v so you should be fine.
BillK
Beautiful Southern Maryland
Busted_Knuckles
Northwest Illinois
240v, sorry, never occurred to me that anyone ran 2hp or the like @ 120v !
Thanks for walking me through that part of it.
Busted_Knuckles
Northwest Illinois
Have you tried pushing something into the little slots on the side ?
Take a look here:
It looks like there might be a screw right in the center of the handle. See if maybe the little round part at the very center might come out.
Pretty sure you nailed it. Good job.
Yeah, started at the slots, also tried to pry the two different yellow layers apart from both sides, just short of ripping them in half... the center of the switch, where its got a bump, and youd expect to find a screw, is solid cast, with the rest of the " knob ". Its not a red dot pushed on top of a screw head, its all one piece... which is why Im having a hard time getting it apart, with damaging it.
Busted_Knuckles
Northwest Illinois
Busted_Knuckles
Northwest Illinois
I just studied that center of the switch where youd expect to find a screw, I picked at it with a box knife, and a small screwdriver, thinking maybe they know how to make a screw trim cap, that is near undetectable when installed ? With a magnifying glass, I still cant see a seam, but tomorrow I will get a pic out of the shop and go after it. Maybe I will move onto a drill bit, otherwise I gonna ruin it trying to pry it apart, nothing to lose at this point,...
