Need some help regarding sawzall blades
husker91
So I was replacing lower control arms on my 89 5.0L mustang, but the bolt is seized in the bushing. I have been recommended to just use a sawzall and cut it off on either end. This is turning out to be much bigger of a chore than I realized, I got the end of the bolt chopped off, but I used all 5 milwaukee metal cutting blades.
And on top of that, that was the easy side, the other side I need to cut would have to first pass through the metal part of the bushing, then through the beefy 12mm bolt. I am wondering which sawzall blade I should purchase as the milwaukee I tried had no noticeable effect on cutting through the bushing.
Thanks!
AceofSpad3s
I have heard good things about lenox blades. I don't have any experience with their sawzall blades since I don't use my sawzall much, even less on metal. But I use their hacksaw blades and I have been very happy with them.
H
husker91
Alright I'll check out the lennox blades when I run to the hardware store tomorrow, and yeah its a tiny little space available for cutting and I don't think I could get enough leverage using a hacksaw. I have even thought about a cutoff wheel if I could somehow slide one in there.
AceofSpad3s
I didn't mean use a hacksaw. Hacksaw blades are the only lenox product I have experience with, which is why I mentioned them. Plus I bet you would be there for quite a while if you were using a hacksaw. :lol:
Ponchoguy
Thanks!
I had this similar problem with the trailing arm on my mother's Saturn SL2. I used my trusty 6.5A Craftsman recip saw and some Lenox blades (I may have used a few Dewalts too) and with some patience, I liberated the SOB. I was like "take that you b***tard" when it finally fell to the ground. LOL.
trackwelder
n.y
What king of blade speed where you cutting with?
If your running the blades to fast your going to burn them up. Cutting is all about speed and pressure.
H
husker91
Awesome, I'll check them out! Thanks! Now would these be better than the diamond tipped Lenox blade? http://www.lowes.com/pd_294633-28303-ES-10833___
I didn't mean use a hacksaw. Hacksaw blades are the only lenox product I have experience with, which is why I mentioned them. Plus I bet you would be there for quite a while if you were using a hacksaw. lol:
Haha if I was doing this by hand I would be at it for a week lol.
Lol that's how I felt after just cutting the one end off! It'll be great once its done, thankfully the other 3 bolts weren't seized in the bushing!! Everyone keeps mentioning Lenox blades, I'll give them a look.
H
husker91
Maybe that's been my problem, first time sawzall user =/. Full speed ahead was my thought lol. The sawzall I rented has a dial from 1-6, I had it on 6.
mechanical turk
Monterey Bay
I haven't cut anything really serious (tend to prefer an angle grinder when possible) but I like the Diablo carbide tipped metal cutting blades.
They are a bit pricey but seem like they'll eat through anything.
kctyphoon
Jersey/Staten Island
any chance of a picture showing what you need to do?? i use diablo blades for the sawzalls i have at work, to cut hardware, anchors and old metal conduit.. is there any chance you can use a propane torch and burn the bushing out if that makes anything easier?
trentonmakes
It's seized in the metal sleeve in the bushing.
At least that's the issue I had removing LCA
Sent from my LG-D801 using Tapatalk
KnurledNut
n/a
This.
If the blades are changing color from the heat, then you are going too fast. If youre running wide open, thats gotta be part of your problem.
This will toast a blade quick on harder metals.
I would definitely slow it down, maybe try the 2nd or 3rd setting on your saw and apply firm pressure.
woody 73
The Great State Up North
husker first thing on Monday morning give lenox a call and tell them your current situation, they will tell you which blade is the best to use and will get the job done asap.
Also ask them where you can buy them and be sure and get a free catalog.
H
husker91
I'll check them out, I believe home depot stocks diablos.
I can try to show you what I'm dealing with, but yeah as trentonmakes said, its a bolt stuck in a metal sleeve.
This.
Alright I'll be sure to turn down the speed when I get back to it! Thanks!
Dagny
Northern Wi.
A sawzall is almost always the most expensive way to cut something. But they are a must for any tool truck.
H
husker91
Awesome, and here is the picture, I tried to make it as visible as possible. The metal sleeve surrounds the bolt, both of which need to be cut through, in about a 1/4" of space...
Sorry for the massive picture...
woody 73
After watching that video on youtube it looks like those carbide teeth from the Diablo will get the job done, heck stop into HD on Sunday and pick up some.
H
husker91
Yeah that thing looks like a beast, might as well go pick one up just to try it out as the Lenox I was looking at isn't sold anywhere around here it doesn't look like. Its worth a shot!
Hpozzuoli
Rhode Island
Diablo blades are the only ones I use. Lennox are the equivalent of dewalt etc.....good for light duty. Diablo are the best. Throw some oil on the blade while cutting.
H
husker91
husker91 the lenox diamond blades look they are for cutting stone work:
http://www.lenoxtools.com/pages/diamond-reciprocating-saw-blades.aspx
After seeing that tool in action clip my money is on those red Diablo blades.
Alright great! I'll definitely go grab one in the morning and put it through the mill. Hoping one blade at a slower pace will cut through it! Thanks for all the help guys, I'll report back sometime in the morning to tell you how it went!!
woody 73
husker91 when you call for your catalog could you ask the folks at lenox if they moved production overseas. Time was when they were top notch blades and all made in America wonder if this is still the case?
trackwelder
n.y
Check out the YouTube video posted above. You can hear the sweet spot when the speed and pressure is just right. I have cut entire vehicles up including the frame with just a few sawzall blades. I am going to grab a few of those carbide blades to try.
trentonmakes
You might try heat
Heat it up and beat it out, may not budge though
I got lucky on the pass side LCA.
Used some heat and a pneumatic punch, flattened the **** out of the punch but the bolt came out lol
His biggest issue is room!
Cut off wheel, Sawzall, hacksaw... There's no room to really get to that bolt, maybe on a lift you'll get more access. It's still a tight space
trentonmakes
Lol
Nope no ASTRO vans
I did find GM puts engine mount brackets in the damn frame though! Lol
404
Mass
That is a grade 8 bolt probably. Put the saw on 1. I get a helper with a spray bottle to constantly put a stream of rubbing alcohol at the cut point. Keep strong pressure on the cut.
H
husker91
You might try heat
^^This guy knows what I'm dealing with! Lol it is no fun at all!
I like the Milwaukee Torch blades,check them out at the Home Depot! http://t.homedepot.com/p/Milwaukee-...cating-Saw-Blades-5-Pack-48-00-5782/100001846
Those are actually what I was using yesterday and I went through 5 of them just getting the one end of the bolt hacked off, albeit with my terrible form...
Yup I went out and bought that carbide tipped Diablo blade and wow, like butter!! Slowed the saw down to about 3 and used some machine oil to keep her lubed up, what an amazing difference the correct tool makes huh!?
Thanks everyone for your help! When I get all the new parts installed I'll post some progress pics!
H
husker91
Here she is off of the car! About time! Now to install new ones with some new springs!
(In the top left of the picture you can see the metal insert in the bushing, glad I only had trouble with one...)
trentonmakes
Heat that ***** up!
Pop out and pop in new bushing!
