Need spdt switch and on off switch with long mounting threads.
bubinga
I have a 2 speed motor on a craftsman 150 drill press, and I want to mount
a spdt and a on off switch in the casting.
I would rather mount them in the casting if I can find the switch's.
I guess the treaded part need to be about 1/2" long.
I need a spdt and a on off.
Would like them to look the same.
Know anywhere that sells this?
Don't see nothing on e bay.
75gmck25
Alexandria, VA
It does not sound like you are looking for anything unusual, unless you want an exact match to existing components.
Try searching some of these places online to see what they carry that might work. Some may advertise on eBay, but that's not the primary source for most new electronics.
http://www.mouser.com/
http://www.altex.com/
http://www.mcmaster.com/
or even http://www.radioshack.com/
Many aftermarket switches for auto parts are also rated at 120 volts, even though they are sold for use in a car. Switches for off-road lights or high power accessories (e.g., winches) might work if they can handle the amperage.
Bruce
Stuart in MN
Minneapolis
Are you talking about a toggle switch like this?
shopping
With a threaded part that's long enough to pass through the casting?
Try Mouser Electronics, Digi-Key or Newark:
http://www.mouser.com/Electromechanical/Switches/Toggle-Switches/_/N-5g2j/
http://www.digikey.com/product-search/en/switches/toggle-switches/1114212
http://www.newark.com/toggle-switches
G_P
Central CT
How thick is the casting? A normal toggle should fit unless for some reason that drill press is built with massively thick castings.
bubinga
shopping
Yes, a switch like that.
I will go measure it.
It is 1/4"
The on off switch I do have from a parts store will fit,
I left it downstairs now. I guess the "stem" l think they call it is about 1/2" long.
But the spdt switch from radio shack is too short.
I don't know if a parts store would have a spdt switch or not.
I will have to check.
Of course some parts stores will not know what a SPDT switch is.
No, I do not want an exact match to existing components. Would be nice if both switches were the same looking, but don't have to be.
Bondo
Greenfield, Maine
It is 1/4"
Ayuh,.... You can find exactly what yer lookin' for in here,.....
