Needs some advice garage repairshop
Pziddy29
Northern NJ
I havent really posted much.I've been very busy and I'm fairly new here.I am looking for some advice as to what to do to resolve my height issue in my garage.So a litleback story on my garage.
The garage is a 2 car 20x25 space.The garage was built after the house was built.Initially the garage wasnt connected to the house.Some time later on it was decided to connect the house and garage via roof and create a breezeway between the house and garage.The roof is a hip style construction.
My current dilemma is this.I purchased a atlas lift last year.I am looking to mark my floor and make the necessary cuts to install the lift.The issue I have is this.I'm not a framing expert and I need some advice wether I can remove the material needed to get to my minimum height of 12'.I am attaching some pictures.
I would imagine that the beams in red are structual to keep the wall from bowing out.
The beams in green are for the side walls it possible they serve a purpose and keep the outside walls from bowing.
Again im not an expert.
I would like to remove the 3 red beams and all the greens.
In place I will install 2 red beams running in the same direction as originals just closer to the sidewall to make the room I need for the length of the car.
After that my plan would be to run the green beams closer to the outside walls of the garage.Possibly adding some triangulation if needed.I am looking to see If I can approach things this way to make sure I have the height for the lift.Any input at this point would be a big help.Thanks.
I am attaching some pictures I took.I am also attaching a top view of what were looking at that I want to change.The blue color in the diagram is the garage door.The red beams run from left to right and the green sections from from front to back.
Falcon67
Merkel, TX
An opinion - that's a mess and it's hard to tell what is going on.
The green parts aren't doing much of anything. They aren't continuous, acting more like spacers rather than rafter ties (joists). Maybe for supporting some sudo attic platform or supporting those "collar ties" which appear to be scabbed on and should be ineffective.
If the red beams run from gable end to gable end, I think they are in the "wrong" place - they are not holding the walls in, they are just supporting the mumbo-jumbo wood antics above. Those should have been running where the green are running.
Really hard to tell what from the pics. If the red lines in your sketch are running gable to gable, there isn't any real need for them or the diagonals you penciled in. (figure 2) The green lines are rafter ties that would tie the rafter tails and top plates together across the space.
slackdaddy1
Southern MD
I did not want to be the 1st one to say it, but yeah that's a mess.
I would personally "Ignore" all the framing except the actual roof plane (rafters, hips, jacks), Then design a workable "under framing" that both meets your needs and will hold it all together.
Nick
P
Pziddy29
Northern NJ
Thanks for the replies.Yes It was like this when I purchased the house.I want the lift to full height as I am 6'2 and frankly its impossible for me to work with my hands above my head, more about the comfort so I dont have to duck.I'm a mechanic by trade.I have a car that I track,a daily and a weekend car.I dont really want to be doing a transmission on my back or with jackstands,hence why the lift.It looks like all the framing doesnt really do much.I just wanted an opinion before I tear it all out.
rnscustom
Plympton MA
It's a mess but anything can be done , maybe an lvl ridge and some collar ties but the picture is not clear . Get a good local carpenter and the lumber yard will usually size up what you need for load carry .
Falcon67
Merkel, TX
I'm 6' 1" and I'll be ripping out part of the ceiling and joists over my 2 post for the same reasons. I'll get at least 90~95% of my lift capacity, that's pretty good for a smaller space.
P
Pziddy29
Northern NJ
Well things have changed this is how it currently looks.
kbs2244
Wow.
That is a dramatic change.
What kind of advice did you get?
scheu
Kansas
That certainly looks better. Did you get to the 12'? Ready for insulation and drywall.
sjvicker
SW Washington
I did the almost the exact same thing on my hip roof last year when I was raising my garage ceiling. The 2x6's that were supposed to span and keep the walls from bowing out had been cut at some point and there wasn't much internal structure to the garage.
Sent from my Nexus 9 using Tapatalk
P
Pziddy29
Northern NJ
I got advice from my father in law who used to do strictly framing some years ago.He told me that it shouldn't be a problem on what I had planned.He helped me do majority of the work as well.The ceiling height is just under 13'.The opening which now exists is roughly 18' in length by 12' wide which should be enough for anything I plan to work on.So I am happy with that.I need to change the way one of the 220v runs is installed.Electrical needs to be finished.Then I need to vent the roof properly and install the insulation and drywall.Speaking of drywall since technically the garage is attached to my home I need to have 5/8" drywall on the wall that separates the garage from the home.Is it worth doing 5/8" on all the walls in my garage??I am looking at this as a added safety point of view as well as possibly to help cut down on the noise coming from the 80gallon air compressor and lift power unit?.
Wow.
kbs2244
Double the 5/8 on the common wall for sound control.
You need tape the last one only.
If you feel you must use drywall, 1/2 is plenty good for the rest.
P
Pziddy29
Northern NJ
This is currently how it looks.Still need to finish insulating and drywall.
Radix2
the thumb!, MI
Looks great, a lot of hard work there.
Having that full hip roof was a blessing, properly constructed, the hip rafters can act as a structure to take all of the loads to the corners, so there are no forces bowing the walls out or rafters needed.
Good stuff.
P
Pziddy29
Northern NJ
So it’s been a long time coming for this project. I am happy to say it is now closer than further. Being that I was furloughed mid March due to the pandemic, I have been working ,trying to finish my garage mahal. A lot of the work was done by me, my uncle and father in law with the exception of electrical and mini split install. Dry way is fire rated 5/8 throughout. Mini split for heat and AC. 80 gallon ir air compressor, Atlas FM9SL fullrise lift with air locks,60 amp sub panel was also installed, wires were run for Ethernet and wall speakers. Left to do is shop light install, install wall speakers, hide all the low voltage wiring into the shelf, possibly install some sort of wall armor towards the bottom and install the floor.
P
Pziddy29
Northern NJ
So the garage is now most painted and floor installed I will try t post some pictures later. I also got my mini split ac sorted so now its nice and comfortable to wrench on my car. This project for me was tough because I had 20 pounds of **** in a 10 pounds bag. I was constantly moving things from place to place. But its finally done. Alot of hard work went into this project but its something I need so it was all worth it. My father, my father in law and my uncle were a big help to me as far as experience went, and actual physical work. They helped me big time without them this would of went on for longer than it already has. Good help is key when undertaking a project such as this.
