bikingpro5
New Canadian- 22x22
First post but a long time lurker, while waiting for the house to be finished i took inspiration for my 22x22 from many great garages here.
This is our first home and we only moved in 3 weeks ago, lots has changed since than but many changes will come I'm sure.
when we were handed the keys to the house the garage was only primed a few days earlier. first thing i knew that had to be done was seal and protect the concrete.
So i used EUC Diamond clear as we had a bit left over at work after doing our warehouse floor. on top of the first coat i threw in some paint chip flakes just to add a bit of color to the gloss clear floor.
day before our final walk through
after a few days of drying
once the floors had setup for a week( no car traffic) I decided to start painting the walls. first thing was 3 days of crack filling, sanding and making sure that the walls would not look terrible once the paint was applied.
the builders were very sloppy in the garage,as you could see every seam on the drywall sheets.
sealed the concrete wall with white paint while waiting on crack filler to dry
started painting the concrete
checking the space around my cars for the first time, wanted to make sure that i had lots of room to work around them if needed
decided mid wall to change from the lighter slate grey to a darker grey for the lower portion of the wall, the upper wall is a semi-gloss white paint.
marking out the line for the blue strip
Also had the hot water tap added to the garage after i had the electric water tank removed from the house and the propane on demand system installed. ( after I had the house keys in hand)
after seeing the white door rails and hangers in a few other spaces i knew i had to do mine as well. Its a nice subtle change.
after seeing the Ikea rods in 55cadillacking's garage i knew that i had a few kicking around not being used so decided to hang one for now for the spray bottles i have.
Out of curiosity is that Focus stock?
Then I read, and went O... Makes perfect sense.
