TangoFoxTrot
- Joined
- Jan 23, 2009
- Messages
- 1,961
I had an older American Standard AC unit that developed a bad leak in the evaporator coil, it would lose like a pound a day. So decided it was time for a new unit. Terrible timing right now.
Salesperson came out and I told him even when things were working, one bedroom of the house just always had weak flow and cooling. Seemed very knowledgable. He thought upgrading the air handler from 3.5 to 4 ton would be the right move, keeping the 3.5 ton condensing unit size. Square footage is around 1600, lots of skylights and windows, Phoenix AZ area. So I ordered a new split system, Trane, xr14 heat pump with Tem6 variable air handler. I honestly wanted a "nicer" Trane, but inventory was out and called other places and had the same story. No idea when inventory levels would return and it's 110 degrees here. I usually prefer "simple" though.
Problem is, new unit is ridiculously loud with the airflow. Like you can't have a normal conversation in the house, sounds like a harrier jet in my living room. Never had this problem previously. Really, really loud. I honestly thought the "upgraded" variable flow air handler vs single speed would be a quieter experience, but that's just the first few minutes of startup. Are single stage quieter in an application like this? Old unit was way, way quieter. if I could have done it over again, would have repaired the A coil even though I felt that was good money after bad.
I got the manual and you can adjust the dip switches, and did so for the 3.5 ton setting down from 4 ton. That helped immensely, but the rooms closest to the air handler are still quite a bit louder than previous unit. Cooling works great, happy with performance. On the other side of the house, I have an old 5 ton unit, single stage, and even the ducts closest to the air handler, it's simply quieter.
The outfit I used was probably the largest Trane dealer in my state, they've been around for like 40 years, and really happy with their service and technicians.
What remedies are there available for this? What the larger air handler a mistake? Is there any harm leaving it on the 3.5 dip switch setting? Any subtle duct adjustments?
