New build concrete coating options?
Matt193
Wi
I had a 28x32 garage built this past fall. I've been slowly working on it this winter getting the insulation installed. I would like to do something with the floor before I start using it and getting stains on the concrete, but I'm pretty overwhelmed with options.
The floor was power troweled so it's very smooth. I originally was thinking of just sealing it or going with something like Ghostshield, but now I'm second guessing myself and thinking of going with something like an epoxy.
I'll be using this as a shop so the floor will be exposed to oil, grease, cleaners, ect. I will be moving snowmobiles in and out, which I plan on being careful with, but the chances of scratching the floor are high.
I really prefer the natural concrete look or a single color so it's easier to find dropped hardware. I also need something that isn't super slippery when wet.
I've contacted a handful of coating companies and have been given ballpark estimates starting at $5-$8 sqft for grinding and epoxy, which is more than I feel comfortable spending, but the $5 options may be doable. All of them have been very negative about just sealing it with something, but a few said they would do it if I really wanted it.
I have no problem going DIY, but I don't want to cause issues down the road or deal with something that fails soon after installation. I'm really unsure about doing surface grinding myself if whatever product I would go with needs it.
I'm also thinking about just forgoing any kind of sealant and using it as-is.
What type of product do you think would work best in my situation?
joebass3
I went with epoxy coating and a top coat called Ballistix. Supposedly very resistant to oil and chemicals. It came in at about $7sqft so it definitely is an investment. I 100% agree to go with a single color. I did flakes on mine and although it looks awesome, I find it tough to find small items that are dropped. They spread a nonslip coating on the surface so it's not slippery.
Personally I would not go the DIY route for epoxy coating. It probably would look good for awhile but it may not hold up over time. Since it was power troweled I'd be tempted to leave it as is if money is tight. Being very smooth will definitely help in keeping it clean.
Shea
California
If you like the look of bare concrete, you may want to consider TS210 by Concrete Sealers USA. It's a thin mil acrylic-modified polyurethane coating and sealer with a matte finish. It's highly resistant to oils, has good wet slip resistance, and good scratch resistance.
The best part is that it's easy to apply DIY, and most concrete surfaces don't need to be prepped with etching or grinding. For a power-troweled surface, a primer coat of equal parts water and TS210 is applied first, followed by two more coats of TS210.
The matte finish does a good job of hiding scratches. However, it's one of the few coatings that are easily repairable if needed. Just rough up the area with 100-120 grit sandpaper, then apply TS210. It can be purchased in quart sizes, making it a good patch kit if the time comes.
Many on the GJ have applied TS210 to their garage floors and workshops with good results. I suggest you read our article below to learn more.
Dig Doug
The TS 210 sounds perfect for my application! I have 2 slabs that I want to coat one is new & one is old
How does it hold up in say extreme heat ? Like 115-120 degrees summer weather in the desert
Thank you for posting !
Question -
Looking to remove some oil stains in a garage
Is there a magic product or technique that makes things disappear?
then top coat w/ TS 210
M
Matt193
Wi
Thanks for this suggestion. It looked like a really promising product and could be the ticket until I read this:
"Furthermore, because TS210 is a breathable, thin-mil coating, it should not be exposed to standing water for extended periods, nor extreme winter weather conditions that track in snow, salts, and deicing fluids that sit for long periods. Doing so may lead to delamination issues."
Extreme winter weather is pretty standard here and my plan is to bring my snowmobile in after rides to let it melt off. I will also be bringing in other snowy and salty things in to let them melt off as well. What are your thoughts on this?
Shea
California
Concrete Sealers USA is very conservative about the performance claims of their products. Part of the reason is that they want to ensure the customer chooses a product that meets their performance expectations. They've even talked customers out of buying a particular product if they feel it won't meet their needs. It's one of the reasons we recommend them. They aren't going to tell a prospective customer what they want to hear to make a sale.
That said, there is a possibility you might have issues if water and salty brine sit for days without being cleaned up. Particularly if you encounter harsh winter conditions. A thin mil, breathable coating can be susceptible to that. Concrete Sealers USA has found instances where water has gotten under the coating, turning it whitish with some delamination, in areas subjected to heavy water exposure. Those areas were covered by floor mats or other items that prevented the water beneath them from evaporating, allowing it to penetrate the coating. As a result, they do not recommend it for heavy to severe conditions such as yours. There have been a thread or two here on the GJ where TS210 was subjected to salty brine and oil that sat for weeks and cleaned up just fine, but there are few such examples.
Thicker, non-breathable coatings perform very well for weather conditions like yours. However, they will be more susceptible to noticeable scratching and damage from the snowmobiles due to the glossier finish. They are also slippery when wet, so an anti-slip media needs to be mixed into the final coat to improve slip resistance.
The best example of a high-performing, budget-friendly DIY coating (compared to non-DIY) that meets these requirements is a single-part polyurea. It is a non-breathable, highly chemical, and oil-resistant coating. Water can't penetrate the surface unless it is scratched down to the bare concrete. Because it is single-part, there is no mixing of A and B components, and unlike other 2-part coatings, you have an almost unlimited pot life (no rushing) to apply it. However, such coatings do require etching the concrete surface first. I attached an article below that discusses single-part polyurea. It also includes images of a clear coat of single-part polyurea on bare concrete.
If you want to avoid etching the surface or don't want to deal with the potential cosmetic blemishes from the snowmobiles, then you might want to reconsider an oil-repelling penetrating sealer such as GhostShield or PS100 by Concrete Sealers USA. They are the easiest to apply and have no worries of damage. Just know that they are still susceptible to staining if oils are not cleaned up in a reasonable amount of time.
BKiller
I chose a cheaper option using a Densifier. Initial application looks good. I was just after stain resistance, nothing pretty.
Quick vid:
M
Matt193
Wi
Quick vid:
Interesting. How long ago did you put that down? Have you done much work on it since you initially applied it?
I'm still mulling over the options that Shea suggested. It's going to be a few months before it's warm enough to apply anything to the floor in my garage, so I have a little time before I need to make a decision. I think I would be happy with either the TS210 or the PS100, but I kind of like the idea of the TS210 a little more as long as it'll hold up.
BKiller
Only been applied for about a week. No real use yet but because it is a chemical reaction to the concrete I don't think it's something that will "scratch off" like a coating will.
Shea
California
Just remember that densifiers technically are not sealers. They react with the minerals in concrete to produce excess Calcium Silicate Hydrate, which tends to fill pores and capillaries at the uppermost surface. This is what makes the concrete denser and harder. Though denser surfaces help reduce liquid penetration, densifiers do not have a repelling action to reduce stains or liquid penetration.
For example, polished concrete is treated with densifiers during the grinding and polishing process. The denser surface produces a better shine. However, the concrete is typically treated with a stain-guard sealer upon completion to help repel liquids and reduce staining.
M
Matt193
Wi
I had a lot of delays this past spring and summer and I'm finally nearing the point of being able to treat my floor with something.
I was just about ready to pull the trigger on TS210 or PS100 until I called Concrete Sealers USA and listened to the salesman? talk about those two products for a half hour. It sounds like TS210 is out for my application and after what the salesman said about the PS100, I'm having second thoughts about using it. I think it would be "ok" for my application, but I don't really like the fact that it sounds like I'll have to retreat the floor every 7 years or so. Once everything is moved in and on the floor, I'd rather not have to move everything to do a recoat in the future.
I'm now leaning towards something like the Nohr-S Polyurea Aegis Coating Kit (without flake) from Legacy Industrial, but I have major concerns about how well the coating is going to hold up long term with just etching the floor. It's a lot of money and time to spend only to have it fail down the road. I haven't called the company yet to discuss what the best route is for me.
Am I overthinking this? I'm really on a tight budget with this and I want to make sure whatever I choose is going to work well long term. Time is ticking as the weather is changing fast. I need to get whatever I'm going with done this month.
I wish I had the money to have someone professionally put a coating on for me, but it's just not something I can swing.
Fav Onefour
MN cold and hot
I can speak to the snowmobile question.
There isn't a coating that will hold up to sharp carbides and studs. If anyone tells you otherwise, they are lying.
Is your outside drive fairly flat? Pick up a good dolly so you aren't running carbides and studs on the floor. Those large tire two wheel units are easy to load and move. Many of them also lift the sled high enough so you can set down onto casters inside the garage. It's a pain lifting a snow filled sled onto casters. The dolly will make it easy enough that you aren't tempted to ride into the garage.
M
Matt193
Wi
It is flat, and I do own a cart but my pig of a sled is difficult to move with it. My buddy uses old conveyor belt on his floor so he can drive his sleds in and out, I'll probably do the same or something similar.
I had a similar experience calling ConcreteSealersUSA for technical advice. If I had gone only based on the first conversation I had with the rep, I wouldn't have bought their products at all - he was doing a pretty good job of steering me elsewhere.
The good reports of TS210 from this forum are what eventually had me calling back. Even then he tried to dissuade me from using the TS210 ("not good for a daily use garage where wet vehicles might be parked"). It was only when I said that this was for my hobby shop where wet vehicles would be rare that he relented the TS210 was a good choice.
I ended up going with PS101 for my exterior concrete (1400ft²) - still kind of on the fence about that one since the concrete as an additive for water repellant but it's absorbing water still so I think it'll be OK) and TS210 for the interior. The PS101 is going on this weekend. TS210 next weekend assuming nothing more pressing comes up.
M
Matt193
Wi
I talked to a guy at Legacy Industrial today and he said that acid etching my floor probably wasn't going to get me the result I need to put down an epoxy type finish. I guess that brings me back to a penetrating sealant or TS210. The thing that really scares me about the TS210 is how much the guy at ConcreteSealersUSA was adamant about not letting any water sit on that sealant.
Have you run across testimonials from people saying that it holds up to water than what he says? Shea alluded to it holding up better than what the manufacturer is saying in one of the posts above, but also cautions me about using it in my area.
I guess I'm back to leaning toward PS101 and densifier or nothing at all. I just hate to make my new floor all oil stained if I didn't have to.
This thread has some info on TS210 vs Coval Concrete and links another thread where a member did a TS210 floor in what sounds like a daily use garage and had no issues with snowmelt impacting the floor once it was cleaned up.
Even in my regular garage, if I pull in a car from the rain, the floor is generally only wet for a short amount of time before it evaporates. The guy I talked to at ConcreteSealersUSA was similarly concerned about using this in an environment where occasional water might be present, but I think as long as I'm cleaning it up in a timely manner and not letting it linger under rubber mats/etc for weeks on end, it should be OK.
I was originally planning to do PS103 followed by PS100 on the interior, but the reports of TS210 from this site ultimately pushed me to that direction. It's a little more work but I think it'll result in a slightly nicer looking finish when I'm done and have better oil resistance.
The PS101 went down yesterday on my exterior concrete. The only real surprise was how far it went - I used 5 gallons for the whole 1400ft² - likely due to the Intraseal in the concrete from the ready mix plant. I will try a water drop test this afternoon to see if it'll take a light topcoat, although that may be a Monday job now with some slight rain chances forecasted this evening.
M
Matt193
Wi
Thanks for linking this thread. After reading another member's experience with Coval, I'm leaning towards that more than anything at this point. I'm going to call Armorpoxy on Monday and talk to them about what my options are. I think TS210 would work for my application, but I also don't want to have to stress over keeping the floor dry if I pull something wet in there.
