New building questions.
showtime96
Edgerton oh
I am getting ready to order a new building and have a few question. Right now I'll keep it to just two. First is I had a quote for perma columns, are they worth it? I'm in northern ohio and my ground seems to hold moisture.
Next is insulation. I considered bookshelf girts and fiberglass or just regular girts and fiberglass. Or what I was thinking is 2 in spray foam and just running liner horizontally up the wall screwed to the posts. Anyone see any problems with this besides dust collecting on the ribs?
Milzo
Hinckley Ohio
How much extra $ for the perma columns? If your going always going to run the heat in the winter I would do the spray foam + fiberglass to get R-19 wall. If you are only going to heat it when your working in there I wouldn't spend the extra $ on spray foam.
My house has a couple inches of spray foam to seal all the penetrations with fiberglass on top. Its a 2350sf ranch so far my highest gas bill has been $106.
showtime96
Edgerton oh
I did the wet set perma columns. loved how the barn turned out. Still working on finishing the inside. I had a guy thta was supposed to run my electric to the barn but hasn't showed yet. What size wire would I need from meter to barn 180' 100 amp box?
manwithtools
Lebanon, TN
Nice shop, 1 Gauge copper or 1/0 aluminum should give 100 amps at 150 feet with acceptable voltage drop. Assuming direct buried or in conduit. If running from the meter, you'll need a breaker there to protect the wire going to the shop. Some have used a 90 Amp branch circuit to supply the shop from main panel and then use 2 gauge copper to save a few dollars.
showtime96
Edgerton oh
Yea it will be from the meter. I just had a new one put in at the road it has a 200 amp breaker for the house but nothing else for the barn just empty slots for more breakers. They have 2/2/2/4 al at menards.
racecougar
Missouri
I'll certainly vote for bookshelf girts. It makes sheeting and sealing the building inside and out a breeze, and provided your girt and post spacing is thought out, it creates bays that fiberglass batts plug right into straight out of the package. I insulated the walls of this entire 30'x60'x13' in a matter of hours, as the only cuts I had to make to the insulation were around the windows and doors. These R-19 batts plugged right into the bays: https://www.homedepot.com/p/Owens-C...s-Insulation-Batt-23-in-x-93-in-E54/303690817
