New compressor question?
2CRUZ
Southern Illinois
Hey Fellas
I just bought me a new Ingersol Rand 5 hp. 80 gal, compressor to put in my new garage. I have never owned a big compressor like this one. I have some questions to ask you guys. After the compressor fills up the tank and shuts off and you are done using it should I turn the shut off valve and leave the tank pressurized or should I let the air out of the tank. Does it hurt to leave the tank with air pressure in it for long periods of time? Also how often should I drain the moister out of the bottom?
Thanks Fellas
WILD-BILL
Brook Park Oh
I leave mine charged all the time. Make sure you have easy acsess to the drain to bleed it of moisture or better yet get an automatic drain.
snowman1981
Crownsville maryland
i turn off the outlet valve incase one of my lines blows out my compressor wont run none stop until it locks up and i extended the water drain on the bottom with some pipe and a ball valve. i drain my when im done using it for the day when in use. depending on use i change my oil in the pump every six months.
stonesfan68
Houston, TX
You can leave the tank pressurized. Close the discharge valve when you are done for the day.
I also highly recommend extending the drain valve out from the bottom of the tank to where you can reach it.
ford33
Chicago, IL. USA
Leave the tank pressurized. No need to run the motor to pressurize an 80 gallon tank every time you need to use the compressor. That will waste money and energy.
It is a good idea to install a valve to separate the tank from the rest of the piping in your system. It will come in handy when you need to make changes to your pipes or replace a quick disconnect fitting. Consider a valve that vents the system pipe pressure but maintains the pressure in the tank often called a "3-way valve" or safety valve.
Ingersoll Rand offers a free 2 year warranty extension if you use their "compressor start-up kit" in their new compressors.
This is from their website:
ingersollrandproductions.com
Start-up Kits:
Ingersoll Rand offers All Season Select® start-up kits to provide improved protection.
Each kit contains all the parts needed to correctly start up and maintain your compressor
for the first year.
The start-up kits provide everything you need for 2,000 hours of service between changes under normal operating conditions, along with the added protection of a two-year extended warranty.
All start-up kits include:
■ All Season Select® lubricant, our
synthetic, all-temperature blend
designed to increase efficiency,
reduce wear and prevent carbon
build-up
■ Replacement air filter elements
2CRUZ
Southern Illinois
So I can just turn the shut off valve and turn off the switch drain the water from the bottom of the tank and I'm good right?
Thanks Guys
larry_g
oregon
Also make sure that you under stand the break-in procedure.
lg
no neat sig line
ZRX61
Solar Blight Valley, SoCal
Thanks Guys
Yup. On my 60gal Devilbis I put a ball valve right next to the original valve just to make it easier to shut off the air feed to the lines.
I also drain mine in the mornings when it is cold & not at the end of the day when the tank is hot & more moisture is suspended in the air.
I had mine wired through a service disconnect on the wall next to it.
Bob C
Breakin varies from manufacture to manufacture but a basic breakin allows the rings to seat,set, and seal and the valves to seal. Run the compressor for 30 minutes without letting it pressurize. Just leave the air blow to atmosphere. This is the minimum for proper btrakin of the unit. Some manufactures require retorqing of the head, etc. your book will tell you. If you bought the unit from a tractor suppy, VERIFY your pump is an American pump and not the chinese cheapie that I/R puts on some of the TSC units. Breakin is different for each.
J Persons
Louisiana
Campbell Hausfield has an extended drain kit that will put the drain within easy reach. It includes fittings, pipe and a ball valve. You can get them at Walmart or Tractor Supply
R6 Racer
Northern Ontario Canada
I leave mine pressurised all the time. I do turn the power to it off when I leave the garage. That way if I have a line leak the worst that happens is the whole system drains. I chose this method because I put the switch right at my bench making it very convenient. I will often not even turn my compressor on if I am only blowing something off or filling a tire.
Steve
Davefr
OR
Steve
I agree. Turn the power off when not being used. I came home to find my IR compressor running continuously because the reed valves failed. (ie when it looses pressure it turns on)
If I hadn't of caught it in time it probably would have either self destructed or maybe even caused a fire.
PT Doc
One manufacturer recommend running 1hr @ constnt ~140 psi for break in.
