New Craftsman 103.22450
Ranchermac
Hey guys, I’m new here and I’ll be fixing up my new to me 103.22450 table saw. Found it on Craigslist and pretty excited to have it. Only thing wrong right now that sticks out to me is the arbor shaft. The arbor shaft is very noisy when it runs and catches when I turn it by hand...hoping it’s just some bad bearings. Seems to be all original minus the switch and it will be a fun project that I plan to use around the garage. I’ve read the few other threads for these on here, but if you have any tips (especially regarding the arbor) let me know. It will be a couple months before I can dig into it but I look forward to sharing the process on here.
For whatever reason the picture wants to upload sideways. Sorry about that!
uberschall
Just North of Detroit
Nice find! Do you have the rail for the fence? If not you should be able to adapt a newer fence system like a Vega.
Once you have it apart, the arbor bearings are usually pretty standard sizes - I was able to cross reference the bearings for my Delta and source high-quality replacements for substantially less than the "service parts" sites listed for my model.
I'd also recommend upgrading to a modern paddle-style switch if possible, I know they don't look very cool but they improve the safety of the unit.
95riosnake
Pittsburgh, PA
R
Ranchermac
Thanks for the help and advice!
As far as the fence goes, I don't have the front rail. Not a biggie because I was planning on upgrading the the Vega like you mentioned. And also as you mentioned, I will install a paddle switch. As much as it might look tacky, I care more about being safe.
When it comes to the bearings, I hear that they are pressed on. 95roisnake, as far as those bearings go do you know if they are USA or outsourced? I was actually messaging that seller just last evening trying to find the correct one. How was the process replacing yours? I'm located out in Idaho. This is the first 50's floor model I've come across so I was excited to jump on it!
This is my first vintage tool rebuild so I will probably have many questions along the way.
95riosnake
Pittsburgh, PA
I will check tonight and see if the packages say the country of manufacture. I haven't gotten to the point of installing them but I did remove the old ones from the arbor shaft, you're correct they are pressed on. There are two internal retaining rings inside the arbor casting that have to be removed before pressing the bearings out of the bore. Currently I have mine completely disassembled and have stripped all the internal parts and repainted them. I still have a good bit more refinishing and a few repairs to do before I start reassembling.
rickhigginshtbr
Lower Bucks, PA
Instead of the Vega, I went with the Craftsman Align-a-rip xrc on my '57. Works beautifully with only a tad bit of adjustment needed out of the box. Got mine off sears parts direct, but they pop on ebay or CL here and there.
exmaxima1
Midwest
Nice find, and probably the only CM table saw I would ever consider owning again. Definitely worth the investment in a modern fence.
R
Ranchermac
I'm going to resurrect this post. Thank you for all the imput thus far. Finally got my saw in my garage today. Here are some pictures I just took of it. I know it is pretty rough, but I think it has good bones and will make for a fun project. Some areas they cut out some sheet metal, drove in some screws, etc. The good news: the knock that it had when I initially looked at it is gone. I have no clue what it was, but now it runs silent. This was with not a ton of pressure on the belt so I don't know if that is a reason.
Do any of you see any missing parts? Anything that is not as it should be? Any ideas as to what the knock might have been?
notlob
norcal
Don't have any info, but here's a pic of your saw on the cover of the 1954 Craftsman Power Tools catalog:
R
Ranchermac
Thanks for the help guys. SSDave, I sent you a pm. Thank you!
I just learned something that maybe you guys can help with. I should have checked this before, but found out the lock knobs on the wheels don't work. When I took them off I found the lock rods were missing along with one collar (not sure the collar is an issue right now though. Any ideas as to how I can replace them? I did some searching but came up empty.
CKS1955
...I just learned something that maybe you guys can help with. I should have checked this before, but found out the lock knobs on the wheels don't work. When I took them off I found the lock rods were missing along with one collar (not sure the collar is an issue right now though. Any ideas as to how I can replace them? ...
If interested I can get the dimensions of my locking rods. It should relatively easy to reproduce.
Jay
R
Ranchermac
That would be great CKS. I just made one that I found the dimensions on for the tilt. I just need to know the dimensions on the height adjustment knob.
CKS1955
Good evening,
I posted pictures for both.
Jay
land of the huskers
CKS1955 thank you so much ! One of my locking rods was missing as well ! Now I can fab one myself. I’m knee-deep in a full rebuild of my 103.22451 floor model. Also maybe you or one of the other fellas can help me. I’m really scratching my head on how to take apart the arbor Assembly. One of the ball bearings is making some noise so I decided to replace the arbor bearings but I am a little hesitant to go tear into it without having a step-by-step. I have the harbor freight bearing pulley kit that I was going to use. Any help is greatly appreciated!
gsprinkel
Texas
Good evening guys, and I'm really happy I found this site. I too am restoring an early 60's model Craftsman 103.22450 I was able to pick up at an estate sale store for $25.00. They had planned to sell it for scrap metal and I couldnt let that happen. Got it home today and plugged in the motor, which ran smooth and quiet.
My first need is the height adjustment handle, one is busted and doesnt turn easily. I intend to clean the saw thoroughly first, then work on the rest of the saw. Its missing several nuts and bolts, but everything else seems to be included. It even has the original fence which is a beast, and solid steel.
Looking forward to contributing as well. I'm an old Hilti and DeWalt guy so feel free to ask me anything about those two particular brands if you need help.
Thanks!
exmaxima1
Midwest
Thanks!
$25 ??!!
Major suckage
gsprinkel
Texas
Can't fault a guy for finding a good deal! :)
I honestly had no idea it was worth any more than that, and found this site giving me a heads up of the true value. It was valuable to me because under the rust and dings is a beautiful piece of equipment. I've been using a 70's model 113 Craftsman for over 25 years.
I've got an old Woodcraft Planer/Moulder if somebody out there needs parts. There's a guy on CL in my area selling one for $1450. (Well, he posted an ad several times, he still has it so it may be a bit overvalued.
gsprinkel
Texas
Would it make you guys feel better if I said I misplaced the decimal? (I didn't, but I'll say I did)
Got it torn down today into basically 3 sections. Hoping to get it cleaned well, lubricated, and back to well functioning.
I have seen a few posts on casters for this but most folks have fabricated a steel base instead of using casters through the bases existing feet. Are they just not sturdy enough for the saw weight? They would raise the height of the saw by about 3".
Has anyone ever used one of the mobile base kits on this saw? I like the way it works on my planer dropping the side down to level and not allowing for any movement of the planer when in use.
Thanks for any input!
Honest Bob
Easton, PA
Yeah I took the factory wheels off mine and put it on a harbor freight mobile base. Works great after I got the dimensions all sorted out (took two tries).
gsprinkel
Texas
Thank you guys, I'll check that model and see if I can get the height right to stay with my existing outfeed tables.
I have scoured the OWWM boards and this one for the gold paint color, which I read in a post, but have been unable to find the post again. I remember the post containing several options including one from True Value. It gave the color code as well as the name. Anyone have that bookmarked?
What are your thoughts on keeping the original fence vs putting my 52" Biesemeyer on this since it will be my everyday saw? The original fence is in good shape, I'm just very trusting of my Biesemeyer. I am a bit concerned the plastic sliding pads on the BM will catch on the webbed wings on the 103. Anyone done this that has suggestions?
Appreciate all the help, this is my first restoration of anything this old.
Thank you.
CKS1955
I use the original fence and have been satisfied with it’s performance, I just make sure to push the head of the fence into the face of the cast iron top prior to engaging the locking mechanism.
Rustoleum Champagne Gold Mist is a good substitute for Craftsman Power Bronze.
Jay
gsprinkel
Texas
Thank you. I have an auto body buddy who has offered to paint for me, spraying the pieces in his paint booth if I supply the paint. I have only found the Champagne Mist in spray cans so far, is it available in quarts?
I can always try to get Sherwin Williams to match it with an Industrial Coating paint maybe?
I appreciate the help. I’ll reattach the original fence and see how it works before making a judgement on replacing with the Bies.
Honest Bob
Easton, PA
Here are some pictures of my saw. I have a
Mule accusquare fence on mine. As long as the tables are lined up properly your fence should be just fine.
gsprinkel
Texas
Very nice! Great job! I hope mine turns out that well. One thing I did yesterday was repair and shore up my hand wheels. After reading all of the threads about the difficulty in finding replacements I filled the back cavity with a clear epoxy from Devcon. One of mine was bent and cracked. I’ll post a couple of pictures of how they turned out if anyone is interested. It definitely beefed them up and you can’t tell from the front they were modified.
How often do you use the extra length on your left rails? I have learned to live with my shorter rails and do most of my plywood sizing with a track saw. It’s just easier for a one man shop and I get great results. Blades on my table saw last longer as well, and the smaller track saw blades are considerably cheaper to replace from the gummy buildup.
CKS1955
Please post pictures of your fix for the hand wheels. Both of mine are in perfect condition, however either on here or over at Owwm.org I posted on whether that filling the back would reinforce the hand wheel. It should make a quite an improvement, I’ve had a handful of these through my shop and if the hand wheel was broken it was always where the spokes attach to the outer circle.
Jay
rickhigginshtbr
Lower Bucks, PA
Bob, how do you have the dust port hooked up on yours? I was debating plexi glass with a dust port down low in that big opening.
Edit: Second picture popped up after I posted this. Odd, lol
gsprinkel
Texas
I’ll post the photos Sunday when I get back to the house, they don’t seem to post from my phone! The filler seemed to significantly strengthen the handles.
Thanks!
Honest Bob
Easton, PA
Thanks, I tore it all apart and put new bearings in it, I also replaced the original 1hp with a 2hp motor. As far as the space on the left I never thought about it before but I never use it.
Its a simple friction fit panel. It works ok and I havent even sealed everything up.
gsprinkel
Texas
Happy Easter guys, I am posting the photos of the hand wheels after filling the back cavity with epoxy. Also a photo of the epoxy I used, which I got at the blue box store and have used for several projects before with good success.
gsprinkel
Texas
Okay I have another question I hope you can help me answer. On my saw the blade arbor seems to have an 1/8” play side to side. The play is in the back at the height adjustment pin which has a large retaining ring and washer on one side. My concern is that the blade would possibly move 1/8” and hit any zero clearance throat plate I used. Does the friction of the belts hold it in place? There does not seem to be any way to “tighten” it other than remove the retaining ring and add another washer. Any thoughts?
CKS1955
There should be no play side to side. I wonder if the a spring washer is missing or damaged.
Jay
gsprinkel
Texas
Thank you Jay. I’ll check the exploded parts lost vs what I see on my saw while it is still out of the cabinet.
gsprinkel
Texas
I completed and reassembled the saw this afternoon. Got the fence installed and have made a few cuts to check and adjust the square. I'm pretty pleased with the end results, and the saw is really a strong saw. Attached a few photos. I do still have the original fence if somebody out there is looking for one for parts.
Thank you to everyone who contributed here or in some other area of the site that I scoured for information and help!
