First, I apologize because I'm sure this topic has been covered, but I want to explain my specific situation. I'm a new member and was referred here from a woodworking forum. I am building a new shop (guised as a garage) and need to decide how to heat it. I will try to give all the relevant information.
Structure: Will be a 500 sf footprint with 10' high walls. Steeply pitched roof w/ a dormer and stairs leading to an upstairs finishing/storage area. 2x6 walls w/ R21 insulation. 10'x8' garage door w/ approx R9 insulation. The roof will have spray foam insulation (unknown R-value).
Environment: Portland Oregon. Winter can get somewhat cold and always wet. Typically we can expect a few cold spells w/ the highs in the 20s. Mostly winter nights in the mid 30s -40 and highs in the 40s. Nothing too cold too prolonged. It is a shop - with dust and everything that goes with woodworking.
Desires: I would like to have a thermostatically controlled heating source. I want to make sure the temperature stays above 35 w/ the ability to reach (about) 60 both downstairs and up. I would like to keep the price below $300. I am able to go higher than that if needed.
I will not be able to use natural gas or wood burning stoves. I'd rather not have propane. I guess that leaves me leaning to electrical heaters, but haven't ruled out a floor radiant heat (but am within several days of that no longer being an option) with a closed system and small electric water heater.
So my questions are: what range of BTU's should I be looking at? Would radiant floor heating be overly costly (both installation and energy usage) for what I' looking for? Would baseboard heaters (or wall heaters) suffice - or even be safe in a shop?
Thanks for any advise and/or web sites you can give.
