2000pstrokeblue
I guess I have 2 questions can you not share a neutral or ground with a GFI using a 12/3 with separate hots/breakers? The other is I ran 2 GFI's on 1 circuit but split them out of the same junction box is this not doable?
Here is a little more info about my problem So im trying to finish the wiring in my new building. I decided to rune 12/3 cable the city is making me run GFI outlets and now that I have it wired up im having some problems. First is that I have the 1 side ran as follows the run comes out of the panel and runs to a junction box, from there 2 legs come out, 1 goes to a single GFI oulet and the other goes to another GFI and another outlet ran from that GFI. When the breaker gets powered on 1 the GFI on its own leg powers up fine the other just pops immediately I have tested the power and ground on the one that pops and everything tests fine, take that GFI out and it also works fine. The second problem im having is with the 12/3 I ran a GFI and another outlet in tandem with no issues. then when I continued on to wire in another light using a different hot and breaker but sharing the neutral and ground they both work fine when only 1 or the other breaker is on but power both up and the GFI pops. Also thought I may have a bad GFI and swapped them out with no change
