I am assuming you are talking about the same compressor. First, it has to be hardwired. There are a lot of threads in the electrical forum and I encourage you to scan them. Even if you hire an electrician, it nice to be informed. There has to be a service disconnect. The breaker can serve as one, if within 50' and direct line of sight. Again, go to the electrical forum for details.
I was able to use my breaker. I will add the disconnect someday. The breaker is a pain to mess with. Right now I am just using it to figure out how I want to do it.
The port is 3/4" I would suggest you scan down the question and answers on the TSC webpage for this product. Two things that you have to do in this class of air compressors that you don't have to worry about in smaller ones. #1 is a regulator. #2 wiring.
Here is a picture of my setup. The things I did that I liked.
#1 is the shut off valve. I am surprised how long the tank will hold air when you don't have a bunch of fittings leaking around. Plus if you need a quick shot of air to blow off something, there usually is enough without starting the compressor.
#2 A simple drain valve. I started looking at automatics styles. I am guessing you read through the thread, but I went with this model.
https://www.grainger.com/product/CONTROL-DEVICES-Drain-Valve-6D913 You can see the lanyard in the picture. When you are next to the compressor for any reason, just give a couple of quick pulls and that is it Put something under it if you are worried about staining. Because of #1 there is always air for this.
#3, there is some debate about bolting down. There is a lot of guys who just leave it on the shipping pallet without any issues. For me, I bought the hard rubber pads and bolted them down. It made fitting my space a lot easier. I don't regret it, but don't feel strongly about it either.
Here is a shot of the drain valve.
