I have ditched the make shift wood stove attempt for a legit potbelly stove I picked up for a hundred bucks. This picture I havnt connected the chimney pipe but I added 2 45 bends to creat kind of an s and a damper. This thing works so great, my non insulated garage gets wram enough to just wear a hoody.
unfortunatly thats all thats happened in the garage, but in the house I have accomplished quite a bit of work.
Here is a little blue print diagram I made to show the layout. Shower on the left, a little dresser island, and shelves and cloths racks along the walls everywhere there isnt windows and will be double stacked for maximum space. Barn sliding door to seperate the room from the bathroom / closet that will just be left open 95% of the time.
I'll first start with my custom floor joist brackets I made to relocated the toilet drain. I didnt want to redo all the floor joists and the ceiling below it so I came up with these.
They allow me to go through the joist and still have structural integrity for the floor. I also made the 2 farthest brackets different to allow for the max amount of pitch for drainage. I also had some previous notching disasters to deal with from previous owners.
I then garilla glued them and bolted them in, 55 bolts in total for 4 brackets.
Once they were bolted in place I drilled the holes for the drain pipe.
new drain pipes and PEX water lines, I love PEX!!
After laying the sub floor I realized my half walls for the toilet and shower should probably be secured down onto the floor joist so I took up a couple sections and then made my half walls. the smaller of the 2 is to just give a bit of blockage for the toilet and its made of 2x4's and the shower is made of 2x6's with built in shelving inside on the shower side. shelves and top pitched correctly for water runoff.
This is the smaller wall onto the joist, it didnt need much to be strong.
the 2x6 shower wall I made sure to beef up. I added this bracket to the joist first
then added another end piece nailed to the joist
I added some tar paper for under the wood floor, just case, and also in the shower to help when I start with the pre pitch
And then layed the wood floor to match the rest of the room
