New septic tank question
man-a-fre
Nebraska
Just got a new septic tank and laterals installed on our acreage and asked the installer if we should put rid ex in and he said "no don't ever use that stuff it will plug up the laterals" .Has anyone ever heard of that? I thought that rid ex would be maintenance on the septic and keep you from having to have it pumped so often. What is the deal
mike93lx
Richmond, VA
If you aren't putting stuff down there that doesn't belong, it absolutely doesn't need any snake oil to keep it running.
Toilet paper, **** and water. That's it
toyotadriver
It's a hot topic. Personally, I know some installers who recommend it and some who don't. I don't know if there are any studies out there that prove or disprove their value. When we built our house (got a new septic), I flushed a few packets down the toilet over the first couple months to get the action started. We run everything into the septic so a little bleach from the sink and washing machine does get into the septic tank (we use it sparingly). So, I add a package of the septic microbe stuff every 6 months or so. Septic is working just fine.
It's more important to keep fats out of the septic tank.
It's also good to keep toilet paper to a min. It won't hurt to flush some down there but less is always better. So, we installed a toilet bowl mounted bidet. Greatest invention ever! You'll never want to poop on a non bidet toilet again once you've used a bidet. Basically, every time you use it, you use it to wash your **** off and then a little toilet paper to dry off. Some people seem to think it's weird but think of it this way....if you got poop on your hand, would you just wipe it off and call it good? Of course not....you'd wash your hands. The bidet is simply washing your **** off. It GREATLY reduces the amount of TP you'll be using.
Another benefit of the bidet is, when there are TP shortages like we had last year, your supply of TP lasts MUCH longer.
Randy in Maine
The Beach
Instead of using something like "ridx", install a tank filter to help keep suspended solids in the wastewater inside the tank and out of the laterals and your system will last longer.
Years ago we specified "Zabel A-1800 tank filters", but there are many similar ones now.
They are normally plastic and every 3-4 years when you get your tank pumped out, they should get rinsed off and get re-installed in the outlet cleanout. I think they are about $100 or so.
Usually they get PVC glued into the 4" PVC headed for the laterals/D-box or the pump chamber. If it ever "plugs up", rejoice because it just saved your expensive leaching field. I have only had it plug up from poorly constructed outlet baffles that fell to the bottom of the tank and from fish scales in a commercial application.
yeldogt
You don't want any solid material to flow out of the tank and into the field ... Additives can become overactive and foam. The foam will float out of the tank and into the lateral.
Years ago with single chamber tanks going to pits or simple fields -- they would clog up and additives got recommended to attempt to free up the system.
Today the tanks are bigger ... 1500 gallons and multi chamber ... solids should stay in the first tank .. the second should get any floaters that make it through. Don't add anything.
Regular T paper should not be an issue ....most places are starting 3 year pump requirements . not going to fill up the solid side in 3 years
walrus
Maine
Mine plugs up every 2 years or so, both my baffles are laying bottom of tank, in and out. I'm thinking I should clean it every year.
Randy in Maine
The Beach
Next time you pump it out, retrofit it sort of like this.....
I will bet your pumper guy does that from time to time.
493mike
mid Michigan
I have two different drain fields and switch between (3 way valve) the two once a year. The drywell boxes scummed over after 7 years causing me to install a regular 4" perforated leaching field. I have had no issues in the subsequent 38 years. No additives, pump every 5-8 years.
Mike
Jackfre
N CA
I had our septic guy stop by to check our 7 yr old septic tank. I had pulled the lid and he was surprised how full of it I am that the tank was not close to needing pumping. TD is spot on with the bidet seat. I speak with the folks from Toto and it is men who are the big fans of the bidet seats. Hairy A**H’s. I always love the comments on these seats. Much to joke about but cleanliness is worth a lot, especially to your *** life. There, that will sell some of them AND benefit the septic system;)
Randy in Maine
The Beach
That's a single chamber ..... not sure you can even use them today.
Some are three now ...huge
I think he was trying to fix what he had.
Regulations are all state or locally specific. Many thousands of them still in use today. 30 years ago, a 2 compartment tank was "new and different". We use to use 2 tanks in series for things like garbage disposals or macerator pumps. Filter always goes on the last outlet.
JRC3
Southwestern OH
Yep, snake oil. All a working septic needs to live and thrive is pee and poop. The bacteria will start and grow all by itself. For the most part if you don't put toxins in there the bacteria is happy and healthy as long as the solids are pumped when needed.
Lets look at the label.
RID-X Septic Tank System Maintenance products will give septic system homeowners peace of mind by helping maintain a free-flowing system. RID-X formula is scientifically formulated with 100% natural bacteria and enzymes to digest household waste. By adding RID-X to the septic system every month, along with regular pumping, you can help prevent expensive septic backups and prolong the life of your system.
Contains Bacteria Cultures, Enzymes, Micronutrients and Water Carrier.
Hmm, so the bacteria and enzymes die every month and need replacing? And There's not enough nutrients in regular waste? WTF is a water carrier; You mean a surfactant, hmm, like in soap? And it doesn't say it works, it says 'it gives you peace of mind.'
And not to mention this.
KEEP OUT OF REACH OF CHILDREN. CAUTION: Contains bacterial spores and enzymes. May cause eye irritation. Avoid contact with eyes. Avoid breathing dusts. Individuals having known allergies, particularly to enzymes, as well as those with respiratory disease or disorders, should avoid contact with this product. Wash hands thoroughly after use. First Aid: If in eyes, immediately rinse eyes with water. Remove any contact lenses and continue rinsing eyes for at least fifteen minutes. If irritation develops, get medical attention. If inhaled, move to fresh air. If irritation develops, get medical attention.
They prey on the uninformed.
doctordirt
Ok, worked in this field for over 40 years. installing and maintaining septics. If you wish to install ridex, so be it, it will not cause any harm. The bacteria in ridex is a supplement or replacement to bacteria that occurs naturally. It is important to have a 2 compartment tank, to have an effluent filter, to have your tank pumped, to have disposal field above high water table. Anaerobic bacteria (without oxygen) live in the tank. Final disposal is done in the drain field with aerobic bacteria (with oxygen). Newer technology uses oxygen injection in to the tank.
yeldogt
He did say "new" ... so I figured multi
yeldogt
Can’t speak for every area but single tank septic tanks are still being installed.
We have to have twins .... even if just replacing.
I just did an up-grade to my property and had to increase the size of the tank as well.
Randy in Maine
The Beach
I used to have an installer who would "bless" each new install with a bushel of horse manure. His work was so good that I really didn't have the heart to tell him it was not needed.
One thing to keep in mind is that the outlet baffles really don't do anything (like keep floaters our of the discharge pipe) until the water level gets up to the bottom of the baffle.
SALIV8
chicago and s/w michigan
At my trailer in mich my septic guy suggests to mix a teaspoon of baking yeast with warm water and flush it down the toilet every so often.
Makes sense to me.
FTG-05
TN
Makes sense to me.
My septic tank guy said the same thing.
He also said never put the following into the septic system:
- "disposable" anything (mine was full of it; they were all black so he said it wasn't from us)
- grease or fats
- heavy chlorine
- harsh chemicals like drain cleaners
- don't use the garbage disposal (or use it very little)
He said ours probably hadn't been done since the house was built (1994); we were very close to having to replace our laterals for $$$$$$. :scared:
yeldogt
You don't need anything .....
A common gravity system is so simple .. if you have one do a google and watch a video -- check out how they work. Understand what type of tank and size you have.
Not pumping them is foolish ... especially if it's an older system. Many have smaller single chamber tanks and fewer laterals. In my area of PA if the old ones fail many people now have to put in sand mounds to meet code .... expensive and ugly.
It's the laterals -- or field that fails. Once the field fails there is really nothing to do -- most areas don't allow simple resurfacing as was once the norm.
As the tank fills with solids the capacity drops -- this can allow more solids to flow out. You don't want any flowing out. Pumping should always include checking the outlet baffle ..
Most system are killed ...
mike93lx
Richmond, VA
A new system (1500 gal) in MA is about 30 grand. Keeping my 50 year old system alive for 230 a year seems prudent. If the diagram in my inspection report is accurate, I only have 3 laterals. It's a single chamber, 1000 gal concrete tank
We had a garbage disposal until a few weeks ago. The regional board of health now disallows them, so it had to come out to pass inspection for my upcoming sale
yeldogt
I get it .... Also .... where are these people who can get systems for 13k?
Just putting the tank in was 11k ... that was part of a 40k quote for other work on the property. So equipment was already there. The two chamber tanks were a requirement ... the single are about the same overall size (I asked) . They do cost a bit more -- think mostly because they require two risers and covers so you can get to both chambers
yeldogt
My current property has an ancient ~800 gallon tank going into a drain field that is maybe 40 x 40 feet, which has a 60ft silver maple right on the edge of it (barely 50ft from the tank) as well as 2 spruce that are easily 50ft tall. From what we can tell, it was installed some time in the 1960's, same time as the well that still works. Some things will never make sense to me. We have had no problems with it but I am wondering when I will have to dig it all up. I have it pumped every 2 years just to be safe.
Some of them work for a very long time. If they never get overloaded.
Are the trees happy !!
Randy in Maine
The Beach
The big money in replacing a septic system is the cost to bring in nice sand and gravelly loam to provide for good drainage under the leaching field. If you live where there is poor drainage and silts/clays native soils, it will require a fair amount of good fill to meet the current plumbing codes. Tanks are cheap. Pumps to pump leachate up a hill are more money.
The things that really kill a septic system is when 1) the leaching field gets "plugged up" with suspended solids in the wastewater and 2) when the anaerobic bacteria living in the leaching field get flooded out and and die. They can get flooded out from above when you use too much water and from below like flooding when groundwater takes away the air for them to breath O2.
Change of use can be a challenge. One person in a house uses a lot less water than a family with kids. When the family buys a house from a little old lady that used 20 gallons of water a day and did a load of laundry twice can be a lot different than having a bunch of teenagers where the daily use is 400-600 gallons of water every day.
If you have documentation to show that you have had your tank pumped on a regular basis over the past 20 year, it can be a selling point. Kind of like buying a car that has had it oil changed on some schedule as opposed to never.
Tree roots also love to plug up a leaching field also since they love to get some of that good nitrogen in the pipe. Not good to have them too close.
mike93lx
Richmond, VA
No choice, at least here. Engineering, the labor, materials, permits.
My septic guy told me the engineering for my 4 bed house would be at least 4k on its own.
JRC3
Southwestern OH
This house I'm in had one, I removed it and installed deep basket strainers instead. I know nothing but what I can't scrape off a plate or out of a pan to the trashcan is the only thing that goes down any disposal, be it septic or sanitary. Even being conscientious of this I still chose not to have a disposal on my 1960 septic system. I also only clean with vinegar and Dawn.
RonRock
Iowa, USA
So does it matter what time of year you have a septic tank pumped? Seems to me that summer heat would have a tendency to dry the field out while the tank is refilling. Seems like a good thing, but just a guess. I've been wrong before.
mike93lx
Richmond, VA
My guy told me it doesn't matter.
jkeyser14
(rural) Maryland
Average household use is 125 gallons per day, so after 10 days even a 1000 gallon tank will be filled.
Randy in Maine
The Beach
When you design a septic system, usually is it based on the number of bedrooms in a residential setting.
The range is about 90-150 gallons per bedroom per day for the total use of the house. When it comes to the leaching area, bigger is generally better.
Pntyrmvr
Headwaters of the GTA, Ontario
Our septic pumper avoids emptying the tank in the coldest winter months to avoid frost heave. He also leaves a bit behind to encourage the bacteria to flourish with the next few flushes.
I’m on the fence as to both ideas, but I haven’t put three kids through school driving a honey wagon so he’s probably right.
“Talk is cheap. Whiskey costs money.”
JRC3
Southwestern OH
...He also leaves a bit behind to encourage the bacteria to flourish with the next few flushes.
There's plenty bacteria left behind in a completely empty tank...He's just getting one more tank pump per truck load by leaving 20% behind in yours.
But I wouldn't argue over 20% of $315 it takes to pump my tank every 5 years.
mike93lx
Richmond, VA
1500 gal is the minimum in my town. That will do up to a 4 bedroom. I believe they increase size from there
