New shop acid stain
kmoon
Modesto ca
It was a lot of work but I hope it will last some time. This was from Direct color.
LegacyIndustrial
deerfield, IL
srleen2: I can't speak for the OP but with our similar products, using a good sealer can range from less than 1.00 psqft to 1.30 psqft.
Always want to use a sealer worthy of garage traffic and chemicals to protect the art-work.
DC73
Lubbock TX
Would acid stain and a good sealer be appropriate for a covered concrete patio that might see blown in rain? Slippery when wet?
kmoon - the floor looks great.
DC
K
kmoon
Modesto ca
Dc73 I first started with buffer and diamond head on it then finished with 80 grit. I needed to level some trial lines. I then sprayed the acid on then waited 24 hours or so, then mopped with neutralizer. I waited 2 days before I sprayed 5 gallons 2-3 coats of sealer. I have with buffer rental 825.00 in this 1200 sq feet shop. I still need to wax it.
My Old Tools
Hamrick Lake, TX
I did 1200sf of acid stained concrete in my old place. I ended up applying the acid twice,, the 2nd time at a higher strength to get the color I wanted. I sealed it with the recommended sealer. It held up well except where my desk chair set. It wasn't a roller chair and the legs eventually wore through the acid stain in that area.
K
kmoon
Modesto ca
Old Tools,
Thanks I'll watch for the ware and try to recoat. I did two coats on my floor too I just didn't clean between coats. I waited about 3-4 hours.
