New shop floor
Full Size 66
Wa.
OK, I am quite sure this question has been beat again-n-again. I am building a brand new garage 28x32. I will have what my concrete contractor called a "burned" finish, in other words very smooth and finished with a power trowel. My goal is to get it as smooth as possible then either leave it or apply a sealer of some sort. This shop will be a working fabrication, mechanical, and storage building. The floor will see a more than average welding, grinding, and heavy vehicle traffic, and some unavoidable spills. I am open to a sealer or coating but it has to be fire proof and resistant to jack stands, hammers, sharp metal edges ETC. Stuff gets droped or slid all the time.
LegacyIndustrial
deerfield, IL
You can apply a densifier for a penetrative sealer that will help keep the burnished look going. Spray apply (bug-sprayer) or mop/roll and you are done. Never need to touch again.
Or...
You can look at a topical sealer, adds protection from stains, fuels, oils and nice gloss sheen. You will have to do some preparation with this as your burned finish is also a bond-breaker to most coatings.
Here is a couple of links:
http://legacyindustrial.net/cart/concrete-densifier-c-22.html
http://legacyindustrial.net/cart/concrete-sealers-topical-sealers-c-28_42.html
Good luck.
F
Full Size 66
Wa.
I like the looks of the sealer for spills, what about fire or hot metal temps on the floor? The densifier is probably the way to go.
gmhill33
What does the desifier do to/for the floor?
Thanks,
Gary
LegacyIndustrial
deerfield, IL
Reactive stains require some type of sealer over top to bring out the color.
Densifiers can be used to fulfill that need.
Yes, they are very compatible with stains.
F
Full Size 66
Wa.
So Legacy are you saying the stain goes on the raw concrete after the burned finish or power trowel, then the densifier? What is the proper order of application? I am hyper paranoid about getting this right the first time, one time!
darkk
Willimantic, Ct.
I'm also interested in this densifier stuff. My floor is about 1 1/2 yrs old and not beat up yet. It will see some welding,grinding and maybe plasma cutting in the future. We were going to epoxy coat it but I don't think that finish will hold up. Will the raw concrete with the densifier alone work for me or maybe color stain and densifier?
LegacyIndustrial
deerfield, IL
F
Full Size 66
Wa.
The densifier can go on after the concrete is cured for a week or so. I feel as if we will have our hands full just getting the foundation and slab poured. If I had time to do it after forms are striped and gone...
F
Full Size 66
Wa.
I'm sorry but if I do the densifier after the pour does that mess up the order for stain? Last post was Power trowel prep, Stain, Densifier. So is any of the product time sensitive or can I do it after the forms are gone, as long as I follow the directions...?:headscrat
F
Full Size 66
Wa.
Thank you I'll see what money is like when we get to the point of application. The stain is a cool thing but money may keep me with densifier only... So are the products from legacy available in the western Washshington area?
F
Full Size 66
Wa.
I'm sorry, I meant are they available in stores like construction supplies or industrial supplies? ....
Nightshift
London, Ontario
Factory direct, shipping is included in the price.
Scotty, I'm thinking of staining and sealing my 240 sq ft garage. It's 25 yrs old, but the concrete is in very good condition. It was originally power troweled and quite smooth. It's been painted a couple times with cheap enamel floor paint that doesn't stay on very well. I know this paint has to be removed before I can stain. Looking at your website, it looks like I need 1 gal of Power Trowel Prep, 2 gal of Acid Stain and 2 gal of Densifier and Waterproofer. I'm expecting my 3,000 psi power washer to remove most of the paint on the surface. There is no oil or other stains on it.
2 questions.
Will the Power Trowel Prep help to remove any residual paint after power washing, or do I need something else to get that off?
Looks like you website offers free shipping currently to me in Ontario, Canada (postal code N0M 2P0)?
Thanks Bill
F
Full Size 66
Wa.
Thanks for all your help on this. I will get back to you after the pour is succesful, the forms are gone, and the back fill is done. I want to be able to walk all the way around, and on or off the slab. The location is tight and access is a problem, I don't want to work my self into a corner.
