New some fab/welding table ideas
Rezarf
Personally. I first looked around for a scrap top first, then designed around the top plate I found. Mine is a 3/8"x22x48 I picked up in 2009 for $65 (about 100-lbs).
Afterward, I built a frame of 2x2 square tube with a frame opening for standing at the table that doesn't get in the way. I measured my height and decided where to cut the risers so I won't be uncomfortable standing at the table. To do that I had to decide which casters to buy first so I would know the overall height added to the risers.
The casters I chose are high-quality 450-lb capacity (ea) I bought from Grainger's and believe me when I say, a quality caster makes a BIG difference when rolling around a table that weighs 300 or 400 lbs. :)
Also gussets are important so your 2-3 inch overhang is reinforced. I also added pegboard at the ends, a frame to wrap extension cord, and left the 2x2 strategically placed so they can be used as receivers for other extensions like a temporary metal chop saw addition. Bet ya can't guess my welder brand. :)
Good luck,
Steve
Steve, awesome table. Lots of good ideas there man, thanks.
cshabang
http://www.garagejournal.com/forum/showthread.php?t=130730
the link to mine..Came out of the INDY area, did time at Godspeed and I bought it from Thom. Its currently being used at my full time job since I dont have a shop of my own currently, but it will be modified to use as a chassis table when I get it home..Mainly Im gonna shorten up the legs and build ramps/stops for it so it will double as a parking spot if need be haha...
bts
Perth. Australia
Pretty simple design, but why over complicate something?
My thoughts exactly.
Heres mine, very basic. 1" plate with wheels.
I have found that the bigger the wheels the better.These are 8" heavy duty. A couple of wheel choks and the table will not move anywhere.
joshuaz223
Central Square, NY
i have a few welding tables ranging from a formed 3/16 steel top from a lift table to a 2" thick 3X6 low table. i got all the tops from junk or scrap. the 2 inch plate i paid just over $290 for. i always just weld to the table top and grind it back off. 2 of my tables have wheels and 3 have vices. the one i use most is a 1/2" plate top 5x6 on wheels with a good vice and clamp bars on the legs. the table can be lifted off the wheels with 1 1/2" bolts in the legs. make sure you leave at least a 4" ledge around the edge of the table to clamp to.
MeridianCreek
kyrbz- those are awesome fab tables. I recently completed the frame for mine. What are the dimensions of them and what gauge of tube did you use? Thanks!
kyrbz
midwest US
Thanks! Each table is 2' x 5'. I used 2" sq. tubing with 11ga. wall. The tops are 10ga. which may be too wimpy for some people, but they work well for me. I often slide them around in different configurations depending what I'm working on.
