New to me compressor
bsaint
Manchester, CT
So Ive had a lot of personal compressors in my lifetime (mostly Emglo) but this was a deal I couldnt pass up.
Its an old Kellogg American 331 pump (5 hp normally) but with a 3 hp setup. Everything is so heavy duty I had to take it apart to get it home. The picture of the pump kinda makes it look small but its about 20" tall. It didn't have a shut off valve so it filled his machine shop lines and the 80 gallon tank in about 7-10 mins.
Its a nice ASME tank with the drain on the side (great feature) so I don't have to bend over to drain the water out of it. This is seen on a lot of horizontal champion tanks. The baseplate is about 1/4" thick!
Im going to clean it all up and restore the 3 hp and use it at my home shop. If its not worth keeping, I have a 3 hp Lincoln super crazy duty motor I bought surplus I can throw on with a Mits drive. This on here is also three phase but Ill build a rotary phase converter with one of my old 7.5hp kicking around for a clean sine wave.
stage20
pcola FL
i got one at a deal and ended up scoring another pump so i have spare parts to fix down the road. i think its going to be working that 3hp motor. most of them are setup to run on a 5. pretty quiet for its size. not sure if you heard it run before buying.
scw1991
gotta love those old motors. I had a Powermatic 12" planer from the 60's that had a 3HP motor with 1-1/8" shaft weighing in at 150 lbs.
compressornew
Canada
This compressor machine is so older for use.I think it's totally refill to again use it.I suggest this compressor machine configuration details is efficient for your work.
See this below :-
Free air delivery: 125 PSIG/ 0 - 212 cfm
Voltages Available: 460/3/60
Horsepower: 60
bsaint
Manchester, CT
No way. Look how small that pulley is. Its like having a 5' cheater bar. Itll prob do OVER 175 without tripping the breaker.
CNGsaves
KS and OK
Reviving old thread to see if OP got the Kellogg compressor up and running ??
That baby is a beast. What RPM will that motor be turning and CFM output ??
bsaint
Manchester, CT
I did. Its actually apart now for a rebuild. I need Kevin to machine me a tool to remove the valves. You should see how thick the low pressure piston rings are. It doesn't really need a rebuild but I moved out of my shop and don't have three phase at home (obviously) so I have time to rebuild it.
I don't know the speed but I put a 5 hp on it with the matching pulley. It keeps up with my sand blaster full blast at 85/90 psi.
Burgerkong
Markham, Ontario, Canada
Hey we have the same vintage compressor along with the same centrifugal unloader! The valves shouldn't need a whole lot of oomph, I actually just used a couple of bolts sized for the right diameter screwed into a short steel plate with a 1/2" square drive hole for the torque wrench (holy sentence runon!).
Mine's a lot dirtier and greasier though.
http://www.garagejournal.com/forum/showthread.php?t=301019
