Memory Leak
- Joined
- Jan 5, 2014
- Messages
- 13
Hello,
I have a torque wrench which I bought from tire rack initially to change my tires (http://www.tirerack.com/accessories/detail.jsp?make=Tire+Rack&partnum=TW605&ID=75). It works perfectly fine as is, however, now I need to change my oil and I want to use this wrench to loosen the drain plugs under the car. These plugs require 18NM to tighten which corresponds to 13 lb/ft torque.
The wrench however only has 20 as the minimum number. The tire rack's website says it's "up to 150 lb/ft" which implies 0 to 150. In addition, I can use the screw like dial to go backwards from 20 to 10 and 0 (even though there is no 10 in the main lever). Is this okay or does my wrench not support torque values below 20?
Thanks.
Thanks.
