pcmeiners
Just purchased a Invertek ODP-12020-USA-I55S off Ebay
2HP AC drive
IP55 / NEMA 12 Washdown duty inverter
Single phase supply
Input: 220-240V single phase, 50/60Hz, 20A (Peak)
Output: 3 Phase, 0-250V, 7.0A, 0-2000
Has internal EMC filter
Questions...
I purchased reactors, one for the supply side (MTE Corp rated 25 amp), and one for the load side, MTE CORP. RL-00802 rated 8 amps. The load side will be connected to older/non VFD rated machine motors ( Delta drill press/Baldor carbide grinder) individually, one at a time. Does anyone use reactors on the load side, for 220-240v?
Would anyone worry about shielded cable from the VFD to the motors used ?, we are only talking 15 feet to the motors at most. The VFD and reactors will be mounted in a sufficient sized enclosure, thus the 15ft.
For the 17" Delta drill press, I figure I will order a 2hp motor 3ph 6.5 amps motor, I figure I am within hp specs of the VFD output, so I should not have any issues, right? I have a 1hp 3p motor but I figure I will lose torque at very low speeds with the 1hp.
Thanks
2HP AC drive
Single phase supply
Questions...
Thanks
