Newborn 255 Caulk Gun
Jland
Colorado
Anybody familiar with these things?? I was given 3 of them, new still in the plastic. They are fairly hefty, certainly not the flimsy pos I am used to and they look to be pretty pricey Grainger has them at $31 and amazon has them at $35. Personally I have never had a caulk gun that lasted more than a couple of tubes so I am curious about these things....
PCustoms
VT
It's probably going to last more then 2 tubes....
I bought a cheap one years ago for a quick 1 off job in an apartment, flimsy POS.
I "broke down" and bought a real caulk gun a few years back, night and day..super smooth, dispenses anything from latex caulk up to super thick cold construction adhesives. Well worth the $30 premium.
onarant
Mississippi
Zoro has it for $25.48. I have had one for 4 to 5 years. I use often and no complaints. They do seem to be well made and will stand up to heavy duty usage.
Rarified27
Between PA and NJ
255 is the larger capacity version of the 250, which I have and have used without any issue for quite a while. The larger thrust ratio, to me, seems to be smoother and definitely helps when using a more viscous adhesive. It's also easy to clean.
J
Jland
Colorado
everything I have seen online about them has been positive. I like that the cage rotates, should be helpful in tight areas and the 18:1 ratio is way beyond the cheesy stamped ones ive been using. ... Thanks for the input guys!!
