Between 265 & 485 SQ/FT Nick's Two-Car Detached Vdub Garage
jonshonda
Wisconsin
Thanks Jon, that is very accurate to me, and I will try to be aware of that last part in particular.
I think the thing I find most frustrating is spending the time and money on something and then either my performance is sub par, or the product is sub par.
A few issues I am dealing with that might amuse you, or that you can relate to.
1) Outdoor hose faucet (hydrant) has been broken for a while. Wife insisted we get an above ground pool for the summer and the vacuum system for cleaning it uses a garden hose. Well pull the guts out, get a rebuild kit, go to put it back in and the threads are trashed on the guts and it won't work. Hey I've got another outdoor hydrant I'll just borrow the guts from that...nope different length and won't work but confirm the part threads in so I know that is the issue. Order new guts, put it back in now and it still leaks with when the water is running. f@ck. **edit**. I purchased new guts from amazon. I noted the seals they came with felt cheap compared to the rebuild kit. Swapped over the supplied seals with the rebuild kit seals and BOOM. No more leaks.
2) Ordered $2700 suspension for the Miata as the original suspension was trash, rattled to beat hell (suspension rattles are my kryptonite), and I plan on getting more into auto-x in the near future. Removed all control arms, inspected all bushings, new ball joint boots/grease, new sway bar bushings and endlinks, new brake calipers, lines, and pads. Waited almost 4 months for the new suspension to arrive, and I've still got rattles to chase down somewhere in the suspension. Lots of time and money spent that didn't fully cure the issue, but got me 95% there. The last 5% will hold the same weight as the 95% I fixed.
3) I blew up my subwoofers in the garage stereo. I got them for a good deal so I'm not too upset, just another thing to add to the list of things to fix.
4) Looking for replacement subs has me now wanting to find a home theater setup.
5) Wife ordered a pool skimmer net from the local pool supply shop, but obv didn't listen to my requests based on the research I did. Unhappy with her $20 net purchase, I returned it and spent $95. Frustrated she didn't listen to my suggestions, but I know the new setup is so much better to use. No one wins
6) I'm really wanting a 3D printer setup and am going down that rabbit hole. Would a $250 setup do to trick, yeah probably but the engineer perfectionist with a pursuit of getting the best possible results has me looking to spend $500.
7) Wanting to ceramic coat the Miata to reduce the amount of time I spend washing it an scratching it. It's very soft single stage urethane paint and typical ceramic coatings are meant to be applied to clear coat. Yet another rabbit hole of applicators, towels, polishes, polishing pads.
N
nicholam77
Minneapolis, MN
@jonshonda I can relate to more than a few of those 🤣
I've attempted to rebuild my outdoor faucet several times. Mine's still leaking 😭
That is giving me PTSD. I did way less work, but when I did the new shocks on the GTI I spent the better part of a year fiddling with the bump stops and trying to figure out where the groans where coming from. Thankfully now all is good.
Nothing to say here except you should do it!
Having been down the low end of 3D printers, I would say go Bambu if you can. I don't have personal experience but all the cool kids say it's the best. X1 or X1C at the top, but even their A1 is pretty well reviewed and can be had for less than $500. Either that or used Prusa Mk3 or Mk4, but personally I would want the Bambu if I was starting over / wanted to dedicate more $$ to it.
You might want to look at @D.F.B thread if you haven't already
Myself, I've given up on the dream of a clean and scratch free car. It had been several months since a wash (through the automated spaghetti machine no less!). But this weekend I had the kids help me.
I tried to explain to them the importance of the two-bucket method, but wouldn't you know my 3-yr old did not seem to care. 🤣
Maybe one day I'll get a paint correction done. I also have some deeper scratches a a few chips on the hatch seam.
And because I washed it, it poured rain the next morning!
Oh well, at least I had a clean car for 10 whole hours.
P.S. If anyone can recommend me a good wheel brush, I'm all ears! The one I had been using was soft and did a good job, but made my hand cramp up and eventually disintegrated. I hate cleaning these spoke-y wheels but my brake dust situation is bad.
loganb
Omaha, NE
Agree with Nick, minimum I'd personally suggest is the "full size" Bambu A1 with what they call the AMS Lite which gives you 4 color/material options at the ready. Step up to a P1P or P1S, but for the bulk of the average users printing PLA or PETG the A1 should do very well for you. I've got one in a box that's coming out in the next couple days and can document it a bit in my thread if you're interested....or hit the youtubes etc for better unboxing/setup videos
If $500 is your budget cap, that's where I'd go. Bumping that dollar up doesn't to me change the recommendation till you get to around $800 to 1k where you could get a P1P or P1S with the AMS on it. The AMS is that good and handy, you don't want one without it.
kaymccampbell
Upstate New York
I bought a round, hot dog shaped wheel brush from Blowes or Blomart. I think it set me back $10.
D.F.B
Australia
Your kids will always remember washing the car with dad.
My Mustang came with hideously complicated Performance Pack Wheels, which are basically Y-Spoke times a million. I tried every brush and wash mitt known to man attempting to find the sweet spot. So, I know the pain.
And there is only one thing worse than cleaning PP1 wheels, its polishing them................................
So, after much trial and error, I suggest the following wheel brushes....................
There are a couple of ways to do this. First, a microfiber brush is going to softest and safest to clean the barrels, but you may run into clearance issues around the caliper and between the spokes. Still worth having one though, the Microfiber Madness IncrediBrush Flat is the one to buy, expensive but will last forever.
You would then have an EZ-Detail brush. These are soft bristled brushes, which are very effective for getting behind calipers or between narrow spokes. These come in small and large, just go the large one. There are red versions of this brush sold for cheaper elsewhere, but they are ****. These are great for engine bay and exhaust tip cleaning too.
For wheel faces, I prefer a smaller wash mitt, either microfiber or wool, this is far more ergonomic on your hands than using a brush.
The alternative to the small wash mitt would be the large "curve-ball" type brushes. I've been using these a lot lately and love how ergonomic they are.
Happy shopping!
jonshonda
Wisconsin
I sourced a new Prier branded stem w/ all orings and gaskets from Amazon, and noted that they seemed to be very thin and cheap compared to the materials in the kit I got from menards. I think it's counterfeit. When I swapped everything over from the Menards rebuild it...no leaks!!
I think I'm just going to have to live with the fact that a 30yo roadster w/ 100k miles isn't going to ride like my 2017 GX460. I've got the reinforced frame rails, butterfly brace, lots of added sound deadening, and added a bunch of insulation. Still a bit noodly on certain road imperfections.
I often wonder if I talk myself into completely overkill and expensive things sometimes due to my obsession with researching new purchases, and I know I do at times. But when my research aligns with suggestions from completely random people on the internet with experience I take great comfort and joy in knowing I'm not too mentally unstable. I've almost completed my order on the Bambu Labs website a few times now, P1S with AMS seems like the best solution to get the results I know I will eventually expect from 3D printing without all the hassle of the older or cheaper machines.
He has given me a ton of useful info. I copied all of his suggestions into a spreadsheet to reference when I'm purchasing the goods.
The thing about hydrophobic coatings is they very much help the car stay cleaner for longer. Even though I haven't tried the advanced ceramic coatings yet, I can tell when the cheaper coatings I use start to wear off. Stuff sticks faster, harder, and accumulates more.
N
nicholam77
Minneapolis, MN
Nick having the kids wash it did way more for them than you. Yes they might have put some scratches but they just built a memory with Dad and that is priceless my friend.
Thanks guys, and yes that was the thought. I washed many a car in my youth and getting wet with the soap, it's so fun for that age. I also like to teach them to take pride in and take care of our collective stuff, including stuff that isn't 'theirs', like nice books, furniture, lamps, etc... grown up things. No, they didn't do a 'perfect' job washing it, but they did listen to me and want to do a good job. Even though they are young, I think they really understand that and like to be involved, and hopefully having some responsibility towards keeping our stuff nice will increase their appreciation for what we have over time, and also not let them grow up into the kind of people that would carelessly door ding someone else's car, for example.
Tbh I'm not that worried about micro scratches anymore... it's just a GTI. 🤣 90% of my washes are through an automatic wash, not even touch-less, although even those are few and far between. The horror! :eek:
You had me at hot dog shaped 🤣
Thank you so much for all the suggestions, that is awesome! I didn't even know about those little mitts. I might pick up one of those and a brush.
Nice! 3D printing isn't a hassle-free hobby, but a better printer helps for sure. I struggled a lot with my first printer, and it made it now fun. I bet you'll be very happy with the P1S w/AMS.
The 20" premium wheels on my CT5 are a part time job. The only/best way for me to clean properly is to use a microfiber by hand.....
Yikes! :eek:
jonshonda
Wisconsin
My "dream" would be to have machine that allows my kids to be creative and print things as well. I'm a design engineer with ADD who has too many hobbies and I KNOW I will make good use of a printer, but I don't want to buy something that requires a lot of my attention. I joined a few Bambu FB groups and overall the Bambu stuff is getting great feedback.
With regards to materials I hate to limit myself to a printer that isn't enclosed as I know sooner then later I will want to start printing with materials that will benefit from a stable and controlled environment. Like I've said before, I can easily find ways to justify jumping up the ladder to more refined and expensive tools, I just need to ensure that investment is less of an "ohh-la-la" and more of an "yeah that would be beneficial and worth the extra cost".
ebarker9
I'm in a similar position, mechanical engineer who actually did some grad work involving FDM printing quite a few years ago. I thought that it would be fun/useful to have a 3D printer now that they're more consumer friendly, went with a P1S and so far I'm really happy with it.
Xti04
you need the Aquor faucets I installed. They are awesome amd frost free as well. They come in different lengths for whatever size your walls are.
Aquor House Hydrant V1+ Frost Free Wall Hydrant Outdoor Faucet with Quick-Connect and Anti-Siphon, Freeze Proof Flush Hose Bib, 6 inch, Slate Gray https://www.amazon.com/dp/B0BDSTD76W?tag=atomicindus08-20
99MPower
Chesapeake, VA
Detailers Domain, and get the wheel brushes
jonshonda
Wisconsin
You guys really aren't helping me save money FOR THE THINGS I SWORE I WAS GONNA SAVE MONEY FOR!!!!
loganb
Omaha, NE
Sounds like a good opportunity to work in some sort of development goal of "improving knowledge and application of modern FDM prototyping methods thru an in depth, hands on self paced online training with industry experts"
This would be code for putting a printer on the expense account and watching YouTube channels :). It's way cheaper then any industry trade show or training you could attend assuming you have to travel for it! Development and cost savings rolled into 1, how could a manager turn that down????
jonshonda
Wisconsin
I'm part of a team that designs and manufactures paint booths....for things like C-130's,F15's, and submarines. We would need one hell of a 3D printer for the stuff we work on!
You actually thought this forum was going to help you NOT spend your money???
I know better then that! There is just so many many many cool things I want and I don't have many many many monies or times to make it all happen. I'm also terrible at adhering to a personal budget, if I want it I have a really hard time not just buying it.
loganb
Omaha, NE
Good thing it's easy to scale models down! Plus the Bambu Slicer allows you to easily split a model into sections in the slicer so it can be reassembled once all sections complete!
We have used them for some factory flow/workflow simulation etc when we have good models for all the stuff. It's kinda fun and cool to do it...but I've found it's easier(and generally better result) to just mock up the workcell with cardboard and tape on the floor as it gives a better feel for the space/cart flow/ergonomics etc.
But yeah...when the things you're working on are that scale and you're more focused on the overall integration then smaller details of the paint mix station or door hinges/latches etc may take a bit more "creative writing" to get that one justified.
jonshonda
Wisconsin
Usually the biggest pain is integration into an existing building and snaking our utilities through existing structure and whatnot. But the slicer program allowing manipulation of larger models sounds really cool. Make me WANT ONE EVEN MORE!!!!
N
nicholam77
Minneapolis, MN
Hmmm, I will give this serious consideration. As mentioned I've attempted to rebuild mine several times, and usually it stops the problem for some weeks or months, and then it leaks again. And the leaking gets worse and worse. We've been using the exterior line shut off in the basement every time we want the outdoor water on or off. It's annoying.
The existing bib / stem connects behind finshed drywall 🤣 , so I don't think replacing it in the same location would be so easy. I might need to reroute from the shutoff to a new spot on the outside wall. I was going to do that anyways... but I like the idea of a different faucet mechanic instead of the same thing I already have. Even though it's pricey.
I have 4" vinyl siding, too, so I'll have to think about some sort of mounting plate on the outside.
This was one of my summer to-do items but I'm thinking at this point in the season I might just save it for next spring 🤣
@D.F.B and @99MPower thanks again for the wheel cleaning suggestions. I ordered one of the Rag Company ULTRA wheel mitts, and the large EZ Detail brush. I think that will be great for starters!
jake28
SF, CA
For anyone reading along and deliberating: just get the Bambu. P1S if you can, X1C if you want to splurge. AMS is nice but definitely not a must have to start. my X1C has been flawless minus a couple botched prints from old filament. A little lube in the lead screws and occasionally replacing the hot end. I know folks with print farms with 20+ X1Cs lined up side by side churning out 1000+ parts/day and they give similarly positive reviews. Early 3D printers were as finicky and attention-needing as a 70s Alfa Romeo. The Bambu printers are like a modern Lexus. Fast, low-maintenance, and just work.
N
nicholam77
Minneapolis, MN
Checking in. Not much has happened since finishing the 1st basement closet. Well, a lot has happened, just not Garage Journal related. About the only thing that's changed with the office / basement project is my planty boi collection has grown a few. Moved the pencil cactus down here to try to get more light.
Aside from that, I've been on a running sneaker rabbit hole. My back pain has gotten better and worse in waves over the summer, but it's mostly migrated to hip / **** / leg pain only on my right side. Sciatica-like symptoms. So much muscle tightness. I've been keeping up my walking, typically doing 10-12k steps a day or around 5-6 miles. Split between several walks a day. However, it's bugging me so much that I might go back to physical therapy again. Anyways... I don't want to give up walking, and was thinking about trying a different shoe to see if it would help.
Typically I wear a pair of old running shoes on my walks (Nike Flex Run 2013)... yeah 11 years old. Tread is almost worn through in the front, but shockingly they are otherwise in good shape with no rips or tears. They are a running shoe, though. Nice and supportive, but quite hard rubber. This was before all the high-stack squishy foam tech came out.
I don't really do running, and I know running shoes might not be the best for walking, but I turned to some running shoe brands that also make shoes that can work for walking or everyday wear, hoping the extra squishy high stack foam models might add some comfort and 'suspension'. I ordered a pair of these Hoka Bondi 8:
Everyone seems to say Hoka is like "walking on clouds". Unfortunately that was not my experience. Yeah they are super plush, and even squish a bit, but I found I had major fatigue on my heels, even just standing around.
Hoka has a great return policy, so I actually wore them on several 3-mile walks which was great to have a real world test. Interestingly, my leg faired much better on both walks. But my heels did not. So I returned them.
Then went to a shoe store, consulted the staff, and tried on a bunch of stuff after doing a lot more YouTube research.
Now I have these New Balance Fresh Foam X 860v14 on order:
They should be good because they are a squishy foam and stability plate hybrid, that gives more support, but also cushioning.
I know that's kind of random to share on here, but like tools, car parts, furniture, software, smart home etc... I tend to go deep and this is what's been keeping me preoccupied.
I did receive my wheel cleaning parts recommended by @D.F.B and @99MPower , and had a chance to wash the car last night after kid bedtime. Wife was working so I was home alone, beautiful night out, and I quickly realized why I never do stuff like this. The kids kept getting out of bed, crying, needing stuff. Every 5min had to run in with soapy hands and shoes to help them. :rolleyes:
EZ Detail Brush Large
This worked great, and was just able to squeeze behind my calipers.
The Rag Company — Cyclone Ultra Wheel Mitt
Also awesome. Perfect size. Still cramped my hand, but easier than my old brush thingy.
I hate dragging out the pressure washer for a car wash. I have a foam cannon for that, but I rarely use it because it's too much set up. Browsing those detailing sites I had my eye on one of these pump sprayers... any opinions on those?
My wheel barrels haven't been this clean since... maybe putting the wheels on last April?
I appreciate the product suggestions, they were just what I was looking for!
I'm hoping to find time to get back to the basement, but not sure when that will be able to happen.
cccoltsicehockey
Charlotte, NC
Car looks nice and shiny back in the garage after a fresh wash. The EZ Detail brushes are great. I have both sizes and love mine.
I agree the pressure washer setup to wash is very time consuming. I know it is a more costly solution than a pump sprayer but a wall mounted setup would cut down on setup substantially.
jake28
SF, CA
Fresh shoes and fresh insoles. My feet and the rest of me seem to be happiest in a pair of La Sportiva Wildcats. They are trail running shoes, and basically all I’ve worn unless there is snow on the ground since 2010. Coupled with cheap eSole inserts which I replace every six months. The orthotics are heat moldable at home; I stick mine in a toaster oven for 20 seconds and they’re good to go. Your experience may vary. Walk on.
D.F.B
Australia
So glad the brush and mitt got you top notch results! The right tool for the job always makes the end result much easier to achieve and more enjoyable too. One other suggestion for wheel cleaning, a bucket dolly and a rolling seat. I used to hate cleaning wheels because of the strain on my knees (I'm a gardener, so I'm always kneeling, 20+ years and my knees are shot). But seated wheel cleaning is so relaxing, I actually enjoy cleaning wheels now. The rolling seat and bucket dolly means you can scoot from wheel to wheel without having to get up!
That seat is pretty universal, and while there are better out there, hello Vyper Chair, but I like the height of this one as its much better for wheels. These are sold by many different brands, the Adams one with the optional padded seat is the one to go for.
The bucket dolly you want is the Grit Guard versions, they are made from thicker plastic. I've linked the Grit Guard site, but they are also available on Amazon and other vendors. You also want the 3-inc casters for smoother running.
Now, the pump action sprayers. I have a love-hate relationship with these in both detailing and gardening. I hate pumping those things up, but then they do make foaming more portable. I have a wall mounted pressure washer, so getting the hose out and using the foam cannon is convenient for me, but having a pump action foamer would more workable for most.
Looking at your garage, I'm guessing you have a air compressor, or at least a small battery powered inflator? Well, iK now make the Foam Pro 2 with a schrader valve, which means you can quickly pressurize the cannister without pumping for 45-minutes. For an extra $9 over the regular model, its a no brainer. Team it with some Brake Buster, and you will be cleaning wheels like a pro!
fourmotioneer
Ann Arbor, MI
I also tried and returned some Hokas, but my issue was with the zero drop design on the pair I tried. From what I’ve heard, some heel can help take tension off the sciatic nerve while standing. I’m not sure if that’s actually true and I’m no physician.
I went to a podiatrist this year - in my mid 30s lol - for some treatment for arch and Achilles pain that might have some overlap so I’ll share: 1) I wear those EVA Birkenstock sandals around the house instead of socks or bare feet. The arch support was recommended 2) I wear a custom orthotic that was free with insurance. If your insurance doesn’t cover custom ($300 out of pocket I believe) then PowerStep makes the podiatrist-recommended insoles. I keep my custom insoles in my dad shoes - Saucony Triumph - and use the PowerSteps in my various running shoes.
SamYoung
Massillon, Ohio
I haven't been through that with Hoka's, but with some Nike FlyKnits that my wife has 4 pair of and loves, but I tried and hated. I'll give a bit of a different perspective on the shoe change. I was having a lot of foot/ankle/planter pain, from severe tightness through my Achilles and hamstring area a couple years ago. I'd also chronically struggled with shin splints while running due to poor form and over-striding. I was severely duck footed (toe out) and had previously had custom orthotics with a high heel and tons of support, though not at the moment.
I ended up going the opposite route with a low stack height, zero drop, wide toe box pair of shoes for my trail running (Altra LonePeak 7) and started to have some relief of pain. Eventually got a pair for everyday and road running (Altra Escalante 3). I probably took about 6 months to transition to wearing zero drop full time. If you do it to fast, you won't give your body time to adjust. For me, the zero drop fixed my gate issue and allowed me to naturally quit over-striding. The low stack height quit hiding my bad form like my cushy shoes and kept me from redeveloping bad habits that had led to repeat injury. It also allowed my feet to strengthen and almost complete got rid of my toe out which I've had since I was a kid by strengthening my arches. I'm definitely a wide toe-box, minimum arch support convert as I believe its universally a benefit to everyone. For me, zero drop works for my natural gate, but I understand that isn't true for all. Too much cush hides bad form, but I'm not a full time barefoot/minimalist convert. As stated above, if you try it, don't do it all at once. It can be a large transition, especially if you've been wearing high stack shoes for a long time like me.
On a separate note regarding the pain, make sure you're getting enough electrolytes. Seems stupid, but its easy to have a deficiency and not know it. During all of this I was having some false planter fasciitis and really tight hamstrings which no amount of stretching or massaging could get rid of. Started tracking my diet and it showed I specifically had a big magnesium deficiency. After I started supplementing it everyday, it hasn't come back.
isonic
Ham Lake, MN
I agree. Again not a podiatrist here, just personal experience. I wear zero rise, wide toe shoes, almost 100% of the time. Work boots are my exception. Drinking water, getting electrolytes, and other vit/minerals can definitly be a contributing factor. Good luck, hopefully you see some improvement soon.
Car looks good. I think it has a perfect daily driver stance :)
N
nicholam77
Minneapolis, MN
Ok, that's what I wanted to know. If pumping them up is annoying. 🤣
I do have a small air compressor. Flipping the compressor on would definitely be less hassle than my pressure washer, which the power cord and pressure hose seem to constantly get tangled. It has no wheels, is awkward to lug around, and I don't like having to switch nozzles or put the foam cannon on and off to rinse etc. Too much fussing. The foam cannon works great, though. I think I will try the iK Foam Pro 2+ with the air compressor fill and see how that works! Because I do miss the foam.
I do have multiple wash bucks w/grit guards, but no dollies or rolling seat. Not sure that I'm ready to drop a lot of money on this stuff, but want to get a few basic things in place. I typically do use a wheel cleaner, can't remember which brand I had last, I think Adam's. But I'm out, so maybe I'll try the Rag Company one next.
I specifically was interested in the Hokas for the cushioning, but also for the low drop (4mm). I don't know the specs on my old running shoes I've been using, but they feel like a bigger drop than that for sure. I read that too big a drop can cause pressure on low back and spine, too, so I wanted to try switching it up. However I've always had tight leg muscles (very inflexible) and maybe 4mm is too low for me? I did notice the most discomfort while just standing in the Hokas.
That is interesting. Maybe if I had given them more time I would have adjusted to the Hokas, but they are pricey and I didn't want to spend that much and not be happy with them out of the box. Figured maybe there was a better option for me.
I've worn flat shoes with no arch support my whole life. Vans and Converse, flip flops, that sort of thing. Never had any issues. In fact I did a few days at Disney World 2 yrs ago in flip flops. When my back pain stuff started 3 yrs ago I did not have these leg problems. That has mostly materialized this year which made me switch to the running shoes on walks, thinking more support might help... but now I'm wondering if they are actually hurting things.
I hadn't heard of Altra, if these New Balance don't work out I am going to give that a look. It's so hard to tell doing a short lap around a store, I wish I could test options out on actual longer walks for a few days. The New Balance have an 8mm drop. They should be delivered tomorrow so I'll get to try them this weekend.
That is a great idea. I've taken basic supplements (like D, C, magnesium, and a few others) here and there, but never really stick with it. I'll try to make a better effort there.
Thanks! I often think about coilovers and going a touch lower still, but only during the summer when I've forgotten I have to daily this car through winter. I have a feeling we aren't going to have a mild winter like last year. 🤣
kaymccampbell
Upstate New York
I have a Ryobi foam cannon and a HF short trigger for my electric PW. That and a turbo nozzle makes cleaning my cars easy peasy. Snap on, snap off, rinse n repeat, drop on lawn chair, swap cars, and again.
cccoltsicehockey
Charlotte, NC
Now not having to not pump one of those things sounds awesome and a great way for in the garage washing when you don't want to fully make a mess of the place. You now make me think the detailing supplies might need one.
D.F.B
Australia
I have iK, Kwazar and Marolex pump action sprayers/foamers. All are well made products, but the iK seems have the edge in overall design functionality, especially the d-handle plunger. With the schrader valve, because the unit has a pressure release valve, you won't over pressurize it with the air compressor.
Adam's products are brilliant, their Wheel & Tire Cleaner is extremely good, as is the dedicated tire cleaner. If you want to try something new, Brake Buster is a worthy choice, especially if you want to use it in a foam cannon or iK foamer. It's not the strongest wheel cleaner on the market, but its excellent for regular washing and also contains corrosion inhibitors. It also functions as a tire cleaner, just use it undiluted for that. For a tire brush, the absolute best is the Detail Factory version.
This is soap from a Kwazar Venus -
This is Brake Buster from a foam cannon -
If you ever want to make some changes to your pressure washer that will make it more convenient, let me know. Adding a longer hose and some key quick connect fittings will make it much more user friendly for car washing.
jonshonda
Wisconsin
Ahh the infinite rabbit holes. It is simply amazing how many products are at our disposal for pretty much any topic.
I will add that I have custom inserts that really do help with supporting in the right places. Not that you have the time, but frequent stretching and strength training is usually a universally accepted way to help the body help itself. Strength training isn't always lifting heavy either, lots of times smaller muscle groups don't get attention they need because the big boys take over when you lift heavy, so concentrating on very low resistance with high reps can be key to getting the little fellas back in shape. The ortho professionals might suggest exercises using resistance bands, do that often and you will likely see positive results.
N
nicholam77
Minneapolis, MN
Thanks, I ordered the iK Pro 2+, right before their Labor Day sale went live. I might send them an email.
I've been to PT on and off, so I have some exercises in the repertoire that I still regularly do. Less than a full program, but some basic core ones. Stretching is tricky... I have a ton of tightness, but lately I've found some stretching maneuvers seem to make things worse.
My latest thought is I have Piriformis Syndrome, which is a chronic tightness or injury of the piriformis muscle. It completely aligns with my current symptoms, including my sciatic-like symptoms. In an effort to try to help myself I made the mistake of using the foam roller too aggressively this weekend, and now it's extra sensitive. I did a lot of reading this weekend, and I think as much as I DON'T want to give up walking, I think I need to give it a break and rest the muscle for a month or so. Even in the two days I've stopped walking it's helped.
I did get the New Balance shoes and I like them, so hopefully I can *slowly* work back up to my walking routine after it's had a chance to calm down and heal.
N
nicholam77
Minneapolis, MN
I had a chance this weekend to do a bit of work around the house and on the basement. One odd end that I've had on the back burner for months is a storage solution for my oil change pump tubes. Now they have a home.
And yeah, knocked out most of closet number 2!
Again it involved trimming width and height, filling the bottom with solid wood, 'mortising' the hinges, etc.
Broke out the MFT extension wings so I could clamp two doors at once.
Inside, I learned my lesson from last time and gave myself room for adjustability with the elongated mounting holes on the hinges.
And it did require some adjustment, but I think I got it to a point where I'm happy.
Now to take them off and to the 'paint booth'.
One thing I can't figure out is what I want to do for pulls. I'm almost inclined to leave them without pulls and have some sort of push-to-open mechanism, because I really like the flush minimal look.
