I came across a screaming deal on an Ingersoll-Rand 80gal T-30 2 stage compressor the other day.
It was disassembled into 3 parts when I got there: pump, motor, tank.
He didn't have 220 so I was unable to test the motor but the motor and pump spun freely so I took the chance.
Got it home, hooked it up to electrical and motor sounds great. Mounted it and the pump. Added oil. It was empty. He said he drained it years before when putting it into storage. And fired it up. Everything sounds really really good. I am very stoked.
Here is how she sit now (Looks to have VERY little use)
Here is where my questions come in.
1) - This is the oil that I put in.
There was 16oz. This compressor doesn't have a view window, or a dip stick. It took the whole bottle. Should this be "full", or should I be adding more? Also, is this the right stuff? I'm in an unheated garage in Colorado, so I figured the synthetic would be the best route?
2) - I'm pretty confident I hook the pump into the tank here
A - is this correct? B - is regular black pipe the route to go? C - Thread tape or pipe goop?
3) - The kick on and shut off thingy (that's the technical name) is missing it's lid which I presume had the wiring diagram.
How is this suppose to be hooked up? I presume its suppose to have the Power from the wall running to this first and then from this to the motor, correct? Can anyone shed light on the proper wiring?
Lastly, any other sweet tips and tricks you might be able to share that I might glean from?
Thanks in advance for answering, I'm sure, very basic compressor woes.
Edit: Air Filter - should I just assume it's trash and replace it? If so are they all created equal or is there a dramatic quality difference?
