not a tool question
brownbagg
went to harbor freight today and got me one of those magnet nail picker upper.
I do a lot of welding in the shop and it works great on grinding dust, no more sweeping, three minute shop clean
Farleyfan
Tennessee
Had not thought of that before but I can see that workin pretty good !
I know it works great after a re-roofing.
tjdux
Southern Nebraska
They need to make a magnet for aluminum and mag shavings. That **** gets everywhere in my little shop.
Not trying to sound like an an *** but aluminum doesn't work with any magnetic materials thanks to phisics.
holt2ton
Michigan USA
^ I'm pretty sure that he was being sarcastic, we used to say the same thing as we loaded aluminum plates on the grinder... " Oh, if we only could afford that fancy aluminum magnet...."
chruler
Vermont
It's also great fun to bring into an appliance store where they sell, (ahem), "stainless steel" appliances. If it sticks, it ain't stainless!
Works great for finding bondo on used cars as well!
PelicanPines
I've hit stainless fasteners that are slightly magnetic... I cut one in half to find it had a slug of steel inside... REALLY??? it has to be costly to do that process... is there really a savings by slugging the inside of stainless fasteners?
One way to get into a good argument is to tell someone who thinks they know everything about metal... some stainless is magnetic. They go all you don't know **** on you. It's fun.
rlitman
Long Island
Not all stainless steel is non-magnetic.
This is true. Another possibility with appliances is that there is a piece of steel directly behind the stainless sheet. That is done with a lot of modern stainless refrigerators, because people like to stick magnets to them. And it is done in appliances, where the cheaper steel structure supports a more expensive stainless exterior.
Then there's the VCM steel appliances that have a stainless look, but aren't stainless.
B.S.A. (ret.)
Central Connecticut
Generally, you will find that the 300 series stainless steels (highly-corrosion resistant) are non-magnetic. The 400 series and other hardenable types of stainless, will oxidize. That's why you will see some pistol parts begin to rust where they come into contact with perspiration, these are magnetic.
